Latest post Thu, Dec 3 2015 4:12 PM by DStone. 54 replies.
Page 3 of 4 (55 items) < Previous 1 2 3 4 Next >
  • Tue, Oct 13 2015 11:26 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,125
    Re: MC 8.4.1 Capture Fail.
    James Vickers:
    Do i need to de activate the licence before removing MC and then reactivate after the reinstall? Or is that not necessary.
    James,
    I have a dongle, and therefor I never de-activate of activate the license. However with software license, I assume you have to de-activate the current version before un-installation and then re-activat with the new installed version. When I un-install an existing version, the installer asks me, whether I would like to de-activate the software first. In my case, I just continue deinstallation. This question may be the last chance to de-activate your license before de-installation.
    I hope, others who run a software licensed MC version will clarify this.
    Joachim
    Joachim Claus
  • Tue, Oct 13 2015 5:22 PM In reply to
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 481
    • Points 6,535
    DStone:
    What firewire chip are you using? You can find this in the Windows device manager in the IEE 1394 controllers section.
    It is the integrated controller on the Gigabyte Motherboard. Windows device manager reports :- Texas Instruments 1394 OHCI compliand host controller
    I guess that supports your theory that TI chipe work better with Media Composer.
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 64GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 441.12) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Wed, Oct 14 2015 1:53 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    Tomas reports that it's working for him as well with a TI chip set. I have the Via chip set. I'm going to get a card with a TI chip and test that.
    Dave S.
  • Wed, Oct 14 2015 10:35 AM In reply to
    • Joachim Claus
    • Posts 948
    • Points 12,125
    Dave,
    I have two different IEEE ports, one on motherboard and one on Soundblaster Audigy 2 ZX. Both have TI chip-sets and both do not work with MC 8.4.1 and 8.4.2, they both work with MC 8.4.
    Joachim
    Joachim Claus
  • Wed, Oct 14 2015 3:43 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    As I'm often wont to quote, '"Curiouser and curiouser!" cried Alice'
    Dave S.
  • Thu, Oct 15 2015 12:47 AM In reply to
    @ Dave.
    Its and old article. but maybe as from how understand it that Joachim's firewire is not dedicated.
    http://avid.force.com/pkb/articles/en_US/faq/en404647
    May still be worth trying the dedicated TI firewire card.
    James.
    Media Composer 8.4. 64bit windows 10,3.5GHz Intel Xeon E5-1650 v3 six core, 16GB of 2133MHz DDR4ecc registered RAM, NVIDIA Quadrophonic k2200 graphics... [view my complete system specs]
  • Sat, Oct 17 2015 5:53 PM In reply to
    • Ken Lewis
    • Joined on Mon, Mar 15 2010
    • West Sussex UK
    • Posts 130
    • Points 1,840
    Hi
    I’m not sure if this is any help?
    Following this thread I have been reluctant to update from my ver 8.3 to 8.4 but as I had finished capturing from my HDV tapes for my current project I decided to give it a try.
    Previously I had messed about deactivating uninstalling and reading what to do generally taking my time to install an upgrade.
    This time I just logged on to the Avid Application Manager and followed the prompts. I’m impressed; it installed MC 8.4.2.27885 like a dream without any problems.
    What has this to do with this thread?
    I can confirm that capturing HDV from my Sony HGR-FX7 works perfectly in 8.4.2.27885 via firewire just like it did before.
    I also have EDIUS Workgroup 8 on the same PC and I was having trouble capturing HDV (mini DV was OK) with both applications which revolved around uninstalling MATROX mini. I can confirm that this has also been resolved since installing 8.4.2.27885.
    Regards
    Ken
    Giabyte GA-X58A-UD3R, 2.66Ghz Intel I7-920 Quad Core HyperThreading processor, 3x 2Gb DDR3 1333RAM-CL9, 1x 320GB Seagate/Western Digital 7200rpm SATA... [view my complete system specs]
  • Mon, Oct 19 2015 12:06 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    Ken, What firewire chipset are you using?
    Dave S.
  • Mon, Oct 19 2015 12:01 PM In reply to
    • Joachim Claus
    • Posts 948
    • Points 12,125
    Ken Lewis:
    What is your HDV-format? I run a JVC BR-HD50 (PAL) in HD 720P50 format. As I said earlier, this deck worked fine with all versions prior to MC 8.4.1.
    In addition, I have tested Capturing with the same system and the same deck under Windows 10 (dual boot workstation with Windows 7-64 Ultimate and Windows 10-64 Professional). I got exactly the same results, i.e. capturing runs flawlessly with MC version 8.4 and fails with version 8.4.2.
    Joachim
    Joachim Claus
  • Fri, Oct 23 2015 1:30 PM In reply to
    • Ken Lewis
    • West Sussex UK
    • Posts 130
    • Points 1,840
    Hi Dave
    Sorry for the delay but I have been away for a few days.
    I’m not that technical for this question but is this what you are asking.
    Texas Instruments 1394 OHCI Compliant Host Controller.
    Intel 955X/ICH7R chipset
    ASUS P5WD2 motherboard
    Ken
  • Fri, Oct 23 2015 1:31 PM In reply to
    • Ken Lewis
    • West Sussex UK
    • Posts 130
    • Points 1,840
    Hi Joachim
    My HDV from my Sony HGR-FX7 is 1080i (PAL)
    I have been away for a few days so I have just given it another try on my return and it still works.
    Ken
  • Sat, Oct 24 2015 6:46 AM In reply to
    • Joachim Claus
    • Posts 948
    • Points 12,125
    Thank you Ken for your information,
     be it makes a difference, whether the incoming digital signal is HDV1 (720P) or HDV2 (1080i). In my case with HDV1 (720p) the isssue is, that I cannot even select a video source in the capture tool, as it is greyed out. As I can capture with other software tools, it is definitely not a driver or deck issue. The problem is just between MC version 8.4.1/8.4.2 and any earlier version.
    Joachim
    Joachim Claus
  • Sat, Oct 24 2015 10:40 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    HDV 1 might be somewhat rare nowadays and it wasn´t so frequently used even during the HDV days so maybe there aren´t so many units available for tests nowadays, not even for the Avid techs, maybe you should open up a support ticket about this.
    Tomas
  • Sun, Oct 25 2015 8:31 AM In reply to
    • Joachim Claus
    • Posts 948
    • Points 12,125
    Hi Tomas,
    I thought the escalation by DStone (see earlier in this thread) should trigger-off Avid's developer.
    Joachim
    Joachim Claus
  • Sun, Oct 25 2015 9:38 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Joachim Claus:
    Hi Tomas,
    Joachim
    That one seems to be more Via chip related Joachim , I´m not even sure if it is an Avid bug.
    Your problem seems to be that with an Avid certified Texas Instrument chip tape capturing of HDV 1 has stopped working with later Avid versions.
    Tomas
