Latest post Sat, Apr 14 2018 11:00 PM by Fernando Sancho. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • Tue, Mar 1 2016 2:32 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,018
    • Points 22,310
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: I can't activate media composer
    Hello HandyGeek,
    HandyGeek:
    I'm having the same trouble. I have a perpetual license (non-dongle) and the application manage shows that MC is activated, but when I launch MC, I get prompted to activate. I don't get it. If one app shows MC as activated, should that not be the case?
    Normally when it's activated it shouldn't prompt you to activate MC again. I'm monitoring this weird behavior of the AppMan. Let me know if you run into this issue again.
    Regards,
    Ralph
  • Sat, Jul 2 2016 10:06 AM In reply to
    • Triangular
    • Joined on Sat, Aug 2 2014
    • Posts 5
    • Points 95
    I have just updated to MC 8.6 and am having exactly the same problem that you describe. I have tried your 'fix' several times without success. I am unable to find a solution to this problem and the moderator on this forum seem to have desserted the forum - Is there another solution yet?
  • Sat, Jul 2 2016 2:15 PM In reply to
    • RalphC
    • Posts 2,018
    • Points 22,310
      Avid Employee
    Hello Triangular,
      Let's reset the AppMan first.
    Reset Application Manager For Mac.
    1. Quit Application Manager from its menu-bar icon at the top of the screen.
              a. Go to MacHD > Applications >Utilites > and open 'Activity Monitor'.
              b. In the activity monitor interface, select the Process Name ‘AvidAppManHelper’ from the column on the left-hand side, Then click the ‘X’ button at the top left to quit the process.
    You should no longer have any ‘Avid Application Manager’ related processes in the ‘Process Name’ column of Activity Monitor.
    2. Delete the following folders:
               HD/Library/Caches/Avid/AppManager/Cache
               HD/Library/Caches/Avid/AppManager/Db
               HD/Library/Application Support/Avid/Licenses
    3. Now once again go to Go to MacHD > Applications > Avid > Application Manager, but this time, double-click on the ‘AvidAppManHelper.app’ file and wait for it to appear in Activity Monitor’s Process list to ensure it’s started.
    4. Restart Machine and launch AvidApplicationManager.app and then re-enter my Activation code and my System ID.
     Reset Application Manager Windows
    Stop the following applications in "Task Manager":
    - AvidApplicationManager.exe
    - AvidAppManHelper.exe
    - C:\ProgramData\Avid\AppManager\Cache
    - C:\ProgramData\Avid\AppManager\Db
    - C:\ProgramData\Avid\Licenses
    Restart computer and launch AvidApplicationManager and then re-enter my Activation code and my System ID.
     Resetting Appman does not help pm your systems ID and Avid master account email.
    Ralph
  • Sun, Jul 3 2016 11:37 AM In reply to
    • Triangular
    • Posts 5
    • Points 95
    Thank you for your reply. I have now tried your suggestions for windows pc and there is no change. I have exactly the same problem - MC8.6 will not activate. I have pm'd you the information you requested.
  • Thu, Jul 7 2016 3:53 PM In reply to
    • RalphC
    • Posts 2,018
    • Points 22,310
      Avid Employee
    Hello Triangular,
     I realized this is a few days ago. However, I did not get any pm. Email me directly raff.condalor@avid.com
    Regards,
    Ralph
  • Mon, Jul 11 2016 12:31 PM In reply to
    • Triangular
    • Posts 5
    • Points 95
    Hello Ralph,
    I sent an email to the address you posted. I have since resolved the issue without your help! I received no reply from my request for help to avid support. So will not be updating my subscription to avid support.
    How did I resolve the issue? Magically. I found a post on the forum by Marianna who explained how to activate MC offline. I followed her suggestions without success. I repeated her suggestion - again without success. So then I tried activation online but still without success. When I tried activation online a second time it worked - magic!
    Thanks for replying.
    Regards
    Triangular
  • Thu, Jul 28 2016 7:37 PM In reply to
    • RalphC
    • Posts 2,018
    • Points 22,310
      Avid Employee
    Triangular:
    Hello Ralph,
    Regards
    Triangular
    Glad it's all sort out.
    Regards,
    Ralph
  • Thu, Jul 28 2016 8:28 PM In reply to
    • Posts 10,736
    • Points 224,820
    Traingluar
    When did you contact support? '
    Phone or Portal?
    Since we are so responsive I want to see where the breakdown was.....  Please let me know so I can trace back.
  • Sun, Oct 8 2017 2:34 AM In reply to
    Hi Ralph,
    I'm having this issue today. It is saying that I have multiple subscriptions on my account but when I check it there is only 1 and it says active but it won't let me launch avid.
    Please help. I'm in a real bind with so much work to do and unfortunatley we can't get adequate accounts support on the phone from Australia due to the time difference with the US.\
    Thank you in advance
  • Sun, Oct 8 2017 8:20 PM In reply to
    • Posts 10,736
    • Points 224,820
    email me off forum.
    include SID
    My Avid email
  • Thu, Apr 12 2018 11:39 AM In reply to
    • Noggin
    • Joined on Thu, Apr 12 2018
    • Posts 1
    • Points 5
    Hi all. I have a similar problem with MC8.2.
    Old MacbookPro died suddenly but Migration assistant transfreed from old HD to new MacbookPro. On launching MC though I get taken to application manager and back to activation screen. Status in application manager is  - activated / permanent.
    Thought I'd try and deactivate but get - Failed Deactivation: 0 Deactivation OK. No record of this device was found.
    Would you recomend uninstall and reinstall or alternative?
    all the best
  • Sat, Apr 14 2018 11:00 PM In reply to
    I have the same problem here... i tried all of the above while waiting someone at avid to respond a case I opened more than an hour ago and still no response...
    im with a very tight deadline and can’t continue my editing since this corrupted my whole media composer installation... now I can’t even go back to trial mode...
    which makes mes you wonder, why spend so much money in a software for a support contract that is not responding ...
