Latest post Fri, Aug 21 2015 7:41 PM by hbrock. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Aug 20 2015 2:51 PM
    windows poping up out of reach for mouse
    When I open a bin with lots of content it sometimes opens up so that its upper frame is out of reach for the mouse. I therefore can only close it by right clicking on the corresponding icon in the main window. Also - moving the window is impossible because the upper frame is out of reach. Very annoying.
    Thanks for any help.
    Peter
    Mac 10.10.4
    MediaComposer 8.3.1
  • Thu, Aug 20 2015 8:02 PM In reply to
    Re: windows poping up out of reach for mouse
    Are those displays overscanning by any chance? (Using hdmi out on a Mac witha consumer display?)
    Most are New MacPro 12 core or 8 Core 2012 MacPros with 24+ Gb Ram nvidia gtx 1070 [view my complete system specs]
  • Thu, Aug 20 2015 8:19 PM In reply to
    Thanks, brainburst. Overscanning is not the problem - it's on the retina display of a macbook pro. Also, I have 2 more monitors connected and no matter on which I open the bin the window will be oversized just the same..
  • Thu, Aug 20 2015 8:30 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 400
    • Points 5,220
    I've also had this happen to me several times on my iMac/MBP.
    The only solution I've found was to "Close All Bins" from the Window menu. Not the best if you're working from multiple open bins.
    I wish Avid would fix this.
    Avid Media Composer 2019.6 Symphony option, Avid Artist DNxID (DNxID Desktop Video Application v11.0), macOS 10.14.5, iMac Pro (2017) 10-Core, 3.0GHz Intel... [view my complete system specs]
  • Thu, Aug 20 2015 11:02 PM In reply to
    • Lux Ainloui
    • Joined on Mon, Sep 12 2011
    • Montreal
    • Posts 9
    • Points 105
    Or you could go in the Windows menu and choose "Home".
    Avid Media Composer 8.2 with Symphony, iMac 27" (mid 2011), 3.4 GHz Core i7, 16 GB DDR3, Radeon HD 6970M 2GB, 256 GB SSD, Yosemite 10.10.1 [view my complete system specs]
  • Fri, Aug 21 2015 1:53 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    OSX 10.10.4 isn't yet supported. This is one reason why.
  • Fri, Aug 21 2015 5:30 AM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 400
    • Points 5,220
    hbrock:
    Unrelated, I'm afraid. I've had this happen on several supported OS's for more than a year.
  • Fri, Aug 21 2015 6:11 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    Would you happen to have more than one monitor and if so, do they have different resolutions?  Trying to get some common details from anybody who's experiencing this to possibly escalate.
  • Fri, Aug 21 2015 7:10 AM In reply to
    Yes - this seems related. I'm using MBP Retina with additional Acer-FullHD Screen and a SONY consumer TV (HDready). When I disconnect additional monitors the problem disappears. However, when monitors are connected the problems occurs on all three monitors just the same.
    OS 10.10.5
    MC 8.3.1
  • Fri, Aug 21 2015 3:20 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 400
    • Points 5,220
    In my case, I'm only using the iMac's and MBP's native monitors. No additional ones connected.
  • Fri, Aug 21 2015 7:32 PM In reply to
    • Greg Cohan
    • Joined on Thu, Apr 9 2015
    • Hollywood
    • Posts 85
    • Points 990
    If I am remebering correctly the trick that always fixed this from me was to switch display from dual monitors back to single monitor in Mac preferences.
    Then switch it back to dual.  Everything pops back into place.
    Greg
    27 Systems all running MC 8.7 on OS 10.11.5, ISIS 5500 SD 4.7.4 client 4.7.7 [view my complete system specs]
  • Fri, Aug 21 2015 7:41 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    Can those afflicted try Greg's solution and report back?  Also, make sure you've de-selected "Displays have seperate Spaces" in the Mission Control settings in System Preferences.
