Latest post Mon, May 30 2016 3:09 PM by BrockH014. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Aug 15 2015 7:32 AM
    • BrockH014
    • Joined on Fri, Aug 14 2015
    • Posts 26
    • Points 350
    Avid-After Effects Workflow?
    What is the most efficient workflow to take media from Avid to AE, add VFX, and then bring clip back to Avid? Without any quality loss.
    I'm working in Avid Media Composer 6 I believe, shot on a Canon 60D, project is 1080p/23.976, footage is AMA linked and transcoded.
    Thanks.
    Filed under: , , ,
  • Sat, Aug 15 2015 12:04 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,438
    • Points 17,730
    Re: Avid-After Effects Workflow?
    Relink your sequence (or subsequence) back to the AMA footage, then AAF export.  Import the AAF into After Effects.  Do your manipulations.  Render from After Effects to a high quality DNxHD movie.  Import  or link that back into Avid and overcut it into your sequence.
  • Sat, May 21 2016 10:49 PM In reply to
    • BrockH014
    • Posts 26
    • Points 350
    I'm receiving this error when I import the AAF into AE. And then I can't see the picture when it's in AE.
  • Sun, May 22 2016 10:19 AM In reply to
    • JKL32
    • Joined on Sat, Dec 22 2007
    • The Netherlands
    • Posts 210
    • Points 2,945
    BrockH014:
    You have to choose 'Pro Import' in After Effects for AAF.
    Avid Media Composer 8.6, BMD UltraStudio Mini Monitor(Desktop Video 10.8), New Mac Pro 8 core, D700, 64g RAM, El Capitan [view my complete system specs]
  • Fri, May 27 2016 6:16 AM In reply to
    • BrockH014
    • Posts 26
    • Points 350
    When I Pro Import that message doesn't come up, but my footage is completely black.
    Here are screenshots: http://community.avid.com/forums/p/160483/809698.aspx#809698
  • Fri, May 27 2016 2:35 PM In reply to
    Do you need to send an AAF? Are your shots complicated or multi-layered or are you basically doing some kind of composite over a single piece of footage?
  • Sun, May 29 2016 6:14 PM In reply to
    • BrockH014
    • Posts 26
    • Points 350
    I mean I could just import the original source clip into AE, but then I'd have to bring that back into MC, sync it, trim it to the original length and then cut it over the original edit to the exact frame. It'd be much easier if I could just export an AAF with the in/out points I want of the particular shot then just pull that shot back in and drop it over when I'm finished in AE with it.
    I'm reading that AAF exporting AMA media can be buggy and not all will port over to AE. So that may be the problem.
  • Mon, May 30 2016 1:12 PM In reply to
    • smrpix
    • Posts 1,438
    • Points 17,730
    It's not a perfect process, partly because Adobe would just as soon you use Premiere rather than Avid.  But the options are:
    AAF a sequence (if it's not too complex) to AE
    AAF an individual clip to AE
    QTRef export a sequence or clip (assuming compatible codec) to AE
    Render out clip in (generallly) DNxHD to bring into AE.
    In any case you will have to import or link to the AE output file.  There is no round tripping.
    If you export your clips to length, re-laying in the Avid timeline should be relatively painless.
    I totally agree, a one click solution through the effects editor would be marvelous.
  • Mon, May 30 2016 3:09 PM In reply to
    • BrockH014
    • Posts 26
    • Points 350
    So basically if I can't AAF AMA-linked media out of Avid, then I have to export online media in DNxHD out of Avid, bring into AE, then export that out of AE in same DNxHD codec and import/AMA back into MC?
