Latest post Sun, Jul 26 2015 8:32 PM by chuckkahn. 7 replies.
  • Wed, Jul 22 2015 2:23 PM
    • chuckkahn
    • Toronto
    • Posts 388
    • Points 4,250
    Crop Timecode Burn-In
    Is there a way to crop the Timecode Burn-In effect so that it just displays HH:MM:SS and not FF?
    Avid Media Composer 2018.12.8 / MacOS High Sierra / iMac (Retina 5K, 27-inch, 2017) / 4.2 GHz Intel Core i7 / 64 GB 2400 MHz DDR4 [view my complete system specs]
  • Wed, Jul 22 2015 3:48 PM In reply to
    Re: Crop Timecode Burn-In
    It appears as though you can drop a 3D Warp effect on top of the Timecode Burn In effect and crop it.
    Not sure if that negatively affects the ability to play back or slows down export, but it appears to be possible.
  • Fri, Jul 24 2015 4:59 PM In reply to
    Nice try but autonesting or nesting crops the BG video too (that old Avid Bug(bear)). When I did this, I think I layered the BG video back over V1 and applied a horizontal wipe to hide the part of the BITC that I did not wish to see.
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2020.6, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Fri, Jul 24 2015 5:10 PM In reply to
    Just did this in 8.3.1.  V1 bars; V2 timecode generator nested in 3D Warp with crop.
  • Fri, Jul 24 2015 5:18 PM In reply to
    Ah - you approached a different way and that does work. I dropped the TC burn in directly onto the clip and that did not work. Thanks!
  • Fri, Jul 24 2015 5:31 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 388
    • Points 4,250
    Thanks!
  • Sun, Jul 26 2015 2:22 PM In reply to
    • blindpew
    • Joined on Sat, Nov 5 2011
    • Posts 45
    • Points 485
    Depending on your requirements, you could also just alter the display / appearance / position settings so that the frames numbers are off the edge of screen
    freelance - hence many and various... [view my complete system specs]
  • Sun, Jul 26 2015 8:32 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 388
    • Points 4,250
    blindpew:
    The position of the timecode needed to be top center in order to simulate the iPhone video recording screen.
