Latest post Wed, Jul 15 2015 8:13 PM by MyriamRenard. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Jul 10 2015 10:53 PM
    AVID MEDIA COMPOSER - Problem to relink a sequence with several AAF titles
    We are having a problem with relink functionality in Avid Media Composer when trying to relink an AAF file to the high rez file.
    The workflow is the following:
    • We use the API to send AAF titles to Interplay
    • The AAF file has a metadata called Tape_ID
    • The high rez file is named after Tape_ID (imported via AMA plugin)
    • We create a sequence from the AAF file
    • We relink by matching Tape_ID metadata from AAF file with the name of the high rez file (see screenshot attached)
    This is working fine.
    The problem is that it is not working for several titles:
    • We create a sequence from several AAF files
    • We import the corresponding high rez files using AMA plugin
    • We relink with the same parameters as above
    • An error message says that the sequence could not be relinked
    Does anybody have an idea why it does not work?
    Thanks in advance for your help.
  • Wed, Jul 15 2015 8:13 PM In reply to
    Re: AVID MEDIA COMPOSER - Problem to relink a sequence with several AAF titles
    The issue above was not correctly described. The actual issue is linked to AMA plugin.
    Please see new post here: http://community.avid.com/forums/p/134743/766641.aspx#766641
    And this post can be disregarded.
    Myriam
