Latest post Sun, May 24 2015 2:57 PM by smrpix. 3 replies.
  • Sun, May 24 2015 11:15 AM
    • S.Clements
    • Joined on Sun, Jul 3 2011
    • London, United Kingdom
    • Posts 812
    • Points 10,765
    Any problems with match frame edits on track filler when making EDLs?
    Hi.
         I'm jumping onto a project by another editor.  There are a lot of edits to the track filler.  Can I export EDLs without any issues?  I don't want to delete the match frame edits because there are a lot of them that I don't want to do individually and am nervous about selecting the entrire timeline and removing them all in one swoop.
    Avid Media Composer 8.3.1 Macbook Pro (Retina, 15-inch, Mid 2014) 2.8 GHz Intel Core i7, 16GB Ram Mac, OS 10.10.2 [view my complete system specs]
  • Sun, May 24 2015 11:33 AM In reply to
    Re: Any problems with match frame edits on track filler when making EDLs?
    No problem. Also, no need to worry if you simply choose "Remove MatchFrame Edits", it won't break anything. But if you leave them in, no EDL problems. EDL's get optimized.
  • Sun, May 24 2015 1:34 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,765
    Thanks, Job.  I guess if there were any difference at all between two clips, even if it were a splice to the same footage, it wouldn't in fact show as a matchframe.  I guess any sort of applied effect, breaks the matchframe.  If there is no scenario possible where deleting all matchframes could accidentally damage the edit, then I will do this in future, just for housecleaning.
  • Sun, May 24 2015 2:57 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,381
    • Points 17,035
    FWIW, in the aggregate I find "remove matchframe edits" tends to solve more problems than it creates.
