Latest post Fri, Apr 24 2015 2:53 PM by Francesco. 2 replies.
  • Thu, Apr 23 2015 10:36 AM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 69
    • Points 680
    PLugin doesn't work under MC8.3.1
    Hi Don
    in these days we have a customer that is using our material under MediaComposer and our plugin doesn't work on his machine.
    Customer have a PC equipped with Window 7 Professional SP1 English Version with MediaComposer 8.3.1.
    I made some test with Media Composer 8.3.0 under Windows 8.1 and all works fine excluding
    the exporting problem I solved as reported in other section of this forum.  Now the problem is that the customer doesn't
    see the images; that is it can import correctly, all data displayed are ok, but the preview window remains green
    (same result if he drags clip on timeline).  So I equipped a PC with some OS (Window 7 Professional SP1
    English Version) and installed initially Media Composer 8.3.1 and experienced the same problem.
    So I make this other test: Uninstalled Media Composer 8.3.1 and installed MC 8.3.0.  Well,
    importing clip now all works fine.  Same results with Windows 8.1 professional.  At this point there
    should be some little variations that prevent decding.  In order to debug I inserted an
    OutputDebugString in every function.  The clip is long 400 frames and dragging it from
    bin to preview I see two calls to SampleMapping:: GetSamplePosition for track 0 (video track).
    One for sample 0 and one for sample 400. But noSampleMapping::ProvideSampleRange calls and
    consequently no decoding.
    Any suggestion ?
  • Thu, Apr 23 2015 1:54 PM In reply to
    • Francesco
    • Pisa - Italy
    • Posts 69
    • Points 680
    Re: PLugin doesn't work under MC8.3.1
    Hi
    I made some further inquiry and found that sequence of calls change from MC8.3.0 to MC 8.3.1
    In detail MC 8.3.0:
    00000001    6.88041544    [4672] NewPclipFromFilePath BLT header read
    00000002    6.88103771    [4672] Read BLT header ok (401)
    00000003    6.88148451    [4672] NewPclipFromFilePath BLT header read
    00000004    6.88152409    [4672] Read BLT header ok (401)
    00000005    10.71132088    [4672] MVP_MSP_BLTAPlugin V 2.00.F  64 bit version beta
    00000006    10.71135712    [4672] BLTAPluginSampleMapping::InitializeInstance
    00000007    10.71159363    [4672] BLTAPluginSampleMapping::SetFilePath
    00000008    10.71173477    [4672] NewPclipFromFilePath BLT header read
    00000009    10.71177578    [4672] Read BLT header ok (401)
    00000010    10.71305084    [4672] BLTAPluginSampleMapping::RegisterSampleRangeHint
    00000011    10.71455765    [4672] BLTAPluginSampleMapping::Prefetch request for track 0, sample 0, numsamples 1
    00000012    10.71537113    [4672] ProvideSampleRange :  before
    00000013    10.71539974    [4672] ProvideSampleRange :  Request 1 samples for track 0 (start sample 0)
    00000014    10.71575356    [4672] ProvideSampleRange :  Allocating 1036800 samples for track 0 (518400.000000)
    00000015    10.71798325    [4672] BLTAPluginSampleMapping::DecodeField
    00000016    10.73050690    [4672] BLTAPluginSampleMapping::DecodeField ok
    00000017    10.75780487    [4672] BLTAPluginSampleMapping::RegisterSampleRangeHint
    00000018    10.75838089    [4672] BLTAPluginSampleMapping::Prefetch request for track 0, sample 0, numsamples 1
    00000019    10.75854111    [4672] ProvideSampleRange :  before
    00000020    10.75856876    [4672] ProvideSampleRange :  Request 1 samples for track 0 (start sample 0)
    00000021    10.75859833    [4672] ProvideSampleRange :  Allocating 1036800 samples for track 0 (518400.000000)
    00000022    10.76072216    [4672] BLTAPluginSampleMapping::DecodeField
    00000023    10.76805210    [4672] BLTAPluginSampleMapping::DecodeField ok
    00000024    10.97340393    [4672] BLTAPluginSampleMapping::RegisterSampleRangeHint
    00000025    10.97394848    [4672] BLTAPluginSampleMapping::Prefetch request for track 0, sample 0, numsamples 1
    00000026    10.97411060    [4672] ProvideSampleRange :  before
    00000027    10.97414112    [4672] ProvideSampleRange :  Request 1 samples for track 0 (start sample 0)
    00000028    10.97417164    [4672] ProvideSampleRange :  Allocating 1036800 samples for track 0 (518400.000000)
    00000029    10.97775364    [4672] BLTAPluginSampleMapping::DecodeField
    00000030    10.98417473    [4672] BLTAPluginSampleMapping::DecodeField ok
    As you can see there is a call to RegisterSampleRangeHint and Prefetch with susequent ProvideSampleRange and Decode.
    While in the MC8.3.1 the sequence is:
    00000001    0.00000000    [1732] NewPclipFromFilePath BLT header read
    00000002    0.00003988    [1732] Read BLT header ok (401)
    00000003    0.00102079    [1732] NewPclipFromFilePath BLT header read
    00000004    0.00106038    [1732] Read BLT header ok (401)
    00000005    0.12420519    [1732] WARNING : Destroying bltPlugin
    00000006    8.74966717    [1732] MVP_MSP_BLTAPlugin V 2.00.F  64 bit version beta
    00000007    8.74968529    [1732] BLTAPluginSampleMapping::InitializeInstance
    00000008    8.75045204    [1732] BLTAPluginSampleMapping::SetFilePath
    00000009    8.75088978    [1732] NewPclipFromFilePath BLT header read
    00000010    8.75094318    [1732] Read BLT header ok (401)
    00000011    8.75191402    [1732] BLTAPluginSampleMapping::SetStorageCallback
    00000012    8.75220013    [1732] BLTAPluginSampleMapping::GetSamplePosition
    00000013    8.75221157    [1732] BLTAPluginSampleMapping::GetSamplePosition called (track 0 sample 0)
    00000014    8.75231266    [1732] BLTAPluginSampleMapping::GetSampleSize
    00000015    8.75232315    [1732] BLTAPluginSampleMapping::GetSamplePosition
    00000016    8.75234795    [1732] BLTAPluginSampleMapping::GetSamplePosition called (track 0 sample 400)
    00000017    8.75324821    [1732] BLTAPluginSampleMapping::GetSampleSize
    00000018    8.85647964    [1732] BLTAPluginSampleMapping::GetSampleSize
    00000019    8.85649776    [1732] BLTAPluginSampleMapping::GetSamplePosition
    00000020    8.85652256    [1732] BLTAPluginSampleMapping::GetSamplePosition called (track 0 sample 400)
    That is we have a call to SetStorageCallback (not present in 8.3.0) and subsequent GetSamplePosition for video track (track 0) and first and last sample. But no other calls.
  • Fri, Apr 24 2015 2:53 PM In reply to
    • Francesco
    • Pisa - Italy
    • Posts 69
    • Points 680
    Hi
    from further investigation I have a doubt: May be that the defaultUncompressedID was changed ?
    My value is:
            const acfUID ContainerWriterPrivate::defaultUncompressedID = {0x04010201, 0x0000, 0x0000, {0x06, 0x0e, 0x2b, 0x34, 0x04, 0x01, 0x01, 0x01}};
    and is passed inside ContainerWriter::GetMediaWriterParameterwhen id equal AMA_MC_ExportVolumeVideoEssenceCoding_ID:
                else if (id == AMA_MC_ExportVolumeVideoEssenceCoding_ID)
               //      pValueUID->InitializeValue(ACFTypeID_UID, &ContainerWriterPrivate::defaultJP2KCodingID, sizeof(acfUID));
                    pValueUID->InitializeValue(ACFTypeID_UID, &ContainerWriterPrivate::defaultUncompressedID, sizeof(acfUID));
                    *pParameter = pValueUID.detach();
    I found that passing the defaultJP2KCodingID the result is the same.  May be that MC8.3.1 uses a slight different key
    for defaultUncompressedID?  I don't see the call to ProvideSampleRange like if MC knows how to decode or attempts to decode it.
    regards
