Latest post Mon, Nov 21 2016 3:28 PM by Marianna. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Mon, Mar 16 2015 9:21 PM
    Media Composer v7.0.4.3 | PATCH AVAILABLE
    Avid is pleased to announce the latest update to Media Composer v7.x code base...v7.0.4.3.
    HOW TO GET
    The latest update to Media Composer is available worldwide as of March 16th, 2015.  This update is free to all owners of Media Composer v7.x.
    - Customers who have already installed v7.x can download the full installer from the Download Center in the Avid Editor Patch folder.
    WHAT'S INCLUDED:
    There are a number of bug fixes, including:
    - In some instances, a LUT did not stay applied to multi-resolution clips.
    - Linking to a QuickTime 4.4.4.4 file created in Da Vinci resulted in an “AMA Plug-In Unable to Provide Sample” error.
    - With Matrox hardware attached, video playback was choppy.
    - Loading sequences with heavily nested rendered effects was extremely slow.
    - FilmScribe might have crashed when trying to preview a change list containing freeze frames and timewarps.
    - SubCap did not display certain international characters correctly.
    - Chinese characters appeared as question marks in a SubCap effect.
    - You might have received an assertion error when AMA linking to an XDCAM file greater than 2GB.
    OS SUPPORT:
    This release supports Mac OS X 10.8.5 (Mountain Lion), 10.9.5 (Mavericks) and 10.10.2 (Yosemite).
    NOTE: Customers with dual 6 core Mac Pro towers (Westmere) and the 2013 Mac Pro with a single 12 core CPU may experience performance issues with transcode, render, and playback on OS 10.10.  These degradations are typically seen with higher resolution material.  The issue has been logged with Apple and we are awaiting an update.
    README:
    The README is currently unavailable.
    FEEDBACK:
    If you have any comments or question regarding the installation of this version, please post it here.  For other bugs or questions, please start a new thread.
  • Tue, Mar 17 2015 4:46 PM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 181
    • Points 2,160
    Re: Media Composer v7.0.4.3 | PATCH AVAILABLE
    Wow. Thanks Avid for the fixes and OS 10.10.2 support. I still have tearing problems in full screen, even with console command moncon off on my retina macbookpro and on external monitor. Tearing appears with Canon C300 25p 1080 AMA material aswell as DNXHD transcoded media. Compositor video is fine though.
    Thanks.
    Andre.
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Tue, Mar 17 2015 10:34 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    Did you select "Flip on Vertical Sync" in the Full Screen Display dialog box?  That should address tearing.
  • Wed, Mar 18 2015 8:49 AM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 181
    • Points 2,160
    yes, that makes it better, but still there is awful tearing mostly in the lower third of the screen.
  • Thu, Mar 19 2015 4:38 PM In reply to
    Kevin Klimek:
    OS SUPPORT:
    Was hoping to get some clarification on the above note. Specificaly the sentence "These degradations are typically seen with higher resolution material".
    Does "higher resolution material" specifically mean "higher than 1080"? And when using the word "typically", does that mean this issue has been seen with projects at 1080 and/or below?
    2.5 floors in Midtown NYC consisting of ~60 workstations, primarily Mac Pros with a few iMacs and Mac Minis. I include specific machine specs in my posts... [view my complete system specs]
  • Thu, Mar 19 2015 5:51 PM In reply to
    Just installed 7.0.4.3 and MC 7 not launching at all.
    Any ideas?
    Model Name: iMac Model Identifier: iMac11,1 Processor Name: Intel Core i7 Processor Speed: 2.8 GHz Number of Processors: 1 Total Number... [view my complete system specs]
  • Thu, Mar 19 2015 8:23 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    Uninstall using the uninstaller. Repair permissions using Disk Utility. Download 7.0.4.3 from Download Center and install full version. If that doesn't work, we need more details: OS version, hardware configuration, error messages.etc.
  • Fri, Mar 20 2015 5:13 PM In reply to
    Did all the stuff suggested.
    On re-launch, I actually got to asking me to register. Skipped it.
    It started launching and then halfway through, crashed.
    Do you need the whole error message or just part of it?
  • Fri, Mar 20 2015 5:23 PM In reply to
    Also, I've posted my system specs in my profile.
  • Mon, Mar 23 2015 12:09 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,065
      Moderator: MCA Mac
    It's hard to fathom what's wrong without a extremely long thread, so I'd suggest calling Avid.  You do get a free call to Avid Support for installation troubleshooting.
  • Fri, Apr 3 2015 12:30 AM In reply to
    • NinaLu
    • Joined on Fri, Jul 12 2013
    • Posts 28
    • Points 320
    Do you know if this addresses a remapping "go to in mark" bug that appears to be on 7.0.4.2?
    http://community.avid.com/forums/t/133257.aspx
  • Tue, Apr 14 2015 6:10 PM In reply to
    • cpeiken
    • Joined on Tue, Apr 14 2015
    • Posts 6
    • Points 80
    When will a patch for MC7 be available for 10.10.3?  I accidently upgraded before AVID approval and I -- like many others on this board -- are having infurating active window problems.
    To quote another poster, "Everytime I open a new window (for example: export or transcode window), I get a "beep" when I click somewhere and nothing happens (the window is blocked for changes). It turns out that I first have to click the window on the upper bar and move it. Then MC notices the window as active and then I can do changes in the window."  Also, there is no render/import progress bar.
    Please advise as this is extremely annoying.
  • Tue, Apr 14 2015 6:16 PM In reply to
    Not sure..Avid usually doesn't post until it's readily available.  I know they are looking at 10.10.3 with the next version of software.  Once they see what issues that may cause, revisions will *probably* ripple down to v8.x and v7.x.
    This should remind everyone of the importance of never upgrading your OS until you know the version of Avid is qualified for it.
  • Sat, Apr 18 2015 1:33 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,217
    • Points 14,730
    Good pratcise is to partition your hard drive and give Media Composer its own, with the required specs. Been doing that for years, most stable editing software around.
  • Tue, May 12 2015 1:25 AM In reply to
    • Alexey
    • Joined on Wed, Mar 5 2014
    • Russia
    • Posts 12
    • Points 100
    Sorry, but when the new update will be avalible? And will it be avalible? Or I have to update to MC8?
    And maybe you know, what about MC6? I have it on my second machine. Will it ever support Yosemite?
    MacBook Pro late 2013 2,6GHz Intel Core i7 16Gb 1600 MHz DDR3 OS X El Capitan 10.11.3 AVID Media Composer 8.5.2 [view my complete system specs]
