Latest post Mon, Apr 20 2015 3:28 PM by Michael from cologne. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Mar 4 2015 3:13 PM
    Waves L2 Ultramaximizer RTAS causes crash when export QT Same as Source
    when I try to export a sequence with an RTAS-Track-Effect as Quicktime Same as source Avid will crash. When I delete the Plugin from the sequence the export works fine. It doesn't matter if the effect is on the master track or not. If I export Quicktime Reference with Audio mixdown it also works fine.
    I did not have this problem on the older MC 6.5.4 (now I'am on MC8.3)
    Anybody experiencing similar problems?
    Anybody having a solution? Thanks,
    Michael
    MC 19.07, WIN 10 x64, HP z840, dual E5-2640v3 2.6Ghz, 8x4GB RAM, Nvidia Quadro M4000, MXO2 LE, Artist Mix [view my complete system specs]
  • Wed, Mar 4 2015 5:46 PM In reply to
    Re: RTAS Effects cause crash when export QT Same as Source
    The Problem seems to be caused only by the Waves L2 Ultramaximizer-Plugin...
    Michael
  • Mon, Mar 9 2015 3:43 PM In reply to
    Hi!
    as writtten above Avid hangs up when I try to export a Quicktime Same as source with the Waves L2 Ultramaximizer Effect on one track. The only solution is to do an Audio Mixdown before, which is not a good workaround in my case.
    The Effect itself is working in the application, just the export without mixdown causes the error. This problem is not happening with the standard avid Limiter/Compressor.
    Anybody experiencing something similar? Anybody an idea for a solution?
    Thanks, Michael
  • Mon, Mar 9 2015 4:21 PM In reply to
    • Posts 11,203
    • Points 231,085
    Michael
    Have you conected Waves to see if that plug in is OS compatible and if it was tested with MC 8.x?
  • Tue, Mar 24 2015 8:29 AM In reply to
    Finally I got feedback from Waves Support: it is a bug and they will try to solve it as soon as possible!
    Michael
  • Mon, Apr 20 2015 3:28 PM In reply to
    Waves send me a patch wich solved the problem. Please contact waves support if you encounter the same problem.
    Michael
