Latest post Mon, Jul 20 2015 5:39 PM by drhundertwasser. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Sat, Feb 7 2015 4:41 PM In reply to
    • Jeff Young
    • Hartford, Connecticut, USA
    • Posts 15
    • Points 185
    Re: Media Composer 7.0.4.2 Patch Available
    coldfusion11:
    Now time to upgrade Fibre manager to support ABOVE OSX 10.7.5.
    Then maybe we could move to mountain lion or mavericks.
    I believe that Coldfusion11 is referring to the fact that the Unity MediaNet client software will not run on Mac OS versions higher than 10.7.5. So, if you have a fibre-connected Unity of a certain vintage, your Mac clients are stuck on Lion.
    Media Composer 2018.12.7 with Symphony Option, on various HP Z4xx and Z8xx workstations, running Windows 7 or 10, with shared storage on an EditShare 7... [view my complete system specs]
  • Sun, Mar 8 2015 12:42 AM In reply to
    Just tried this update on OSX 10.8.5.
    It won't launch for me. Crashes at initialiizing settings.
    I tried trashing all settings and did a full reinstall. No joy.
    Anyone else have this problem?
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Tue, Mar 10 2015 3:45 AM In reply to
    • farmgurl
    • Chicago
    • Posts 42
    • Points 460
    Can I download this patch (free) if I am running 7.0.2? My biggest issue is Avid Pan and Zoom not working consistently(sometimes images will import and sometimes won't and I have a black hole), and I don't know if this even addresses that problem.
    MC 7.0.2, Mac Pro 2 x 2.4GHz 6 Core 2 intel Xeon, 12GB, ATI Radeon HD 5770, 10.7.5 OS [view my complete system specs]
  • Tue, Mar 10 2015 4:28 AM In reply to
    farmgurl:
    Yes and it is an advisable update IMO
    farmgurl:
    P&Z  fixes I could find in a quick run through of the 7.0.3 and 7.0.4.x readme's
    From 7.0.4.1's readme fixed "Bug Number: UDevC00185574. An image with a long name that resided at least 5 folders deep on an ISIS system, did not import into an Avid Pan & Zoom effect.
    From 7.0.4s readme "Bug Number: UDevC00182411. You could not link to a Pan&Zoom image created on a v5.5.3.7 editing application"
  • Tue, Mar 10 2015 4:36 AM In reply to
    • farmgurl
    • Chicago
    • Posts 42
    • Points 460
    thank you! I appreciate quick response. I am not sure that those fixes with cure the problem but it is likely worth update anyway. I do have compositions that go back to MC 3.0.
    I am wondering if it might have something to do with size of target file or the way it was scanned in the first place.
  • Tue, Mar 10 2015 6:10 AM In reply to
    farmgurl:
    Same here and a lot further back as well. Smile
    farmgurl:
    I do not use Mac based Avid's often enough to give a Mac answer for your issue
    Some members here had had similar (if not the same) issues on PC's. Other members with the same MC versions and similar systems did not have the issues (I am one of them)  The most regular suggested solutions involved getting the file path to the graphics folder to be as short as possibe and on internal rather than Mapped network drives.
    Good Luck
  • Tue, Mar 10 2015 6:52 AM In reply to
    • farmgurl
    • Chicago
    • Posts 42
    • Points 460
    that is an excellent suggestion. I had not thought of that (nor found that suggestion previously).
    thanks again
  • Mon, Jul 20 2015 5:39 PM In reply to
    Thank you, thank you, thank you. :-)
    I had no idea why when I upgraded to MC 8 the scrubbing got so funky. I didn't know about the "fast scrubbing" setting, and when I turned it off, everything works fine again.
    MacBook Pro (Retina, 13-inch, Early 2013) Processor: 3 GHz Intel Core i7 Memory: 8 GB 1600 MHz DDR3 Graphics: Intel HD Graphics 4000 1536 MB Hard Drive... [view my complete system specs]
