Latest post Tue, Jan 27 2015 7:57 PM by Christie Carr. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jan 2 2015 4:43 AM
    Command-C Copy doesn't work in columns
    Hey there. I just upgraded to Avid Media Composer 8.3. I've been managing an online and unfortunately need to modify some start timecodes to relink to some AMA media. So, I've mounted my AMA media and have been trying to copy and paste the start timecodes onto the sequence's corresponding clips. The only annoying thing is that none of my modifier keys have been working when I've selected the text in a given column (like the Start column). I have to right-click to pull up the text context menu (copy, paste, etc) and select copy. Then I have to do the same in the sequence clip's Start column. It's very annoying and takes much longer than just being able to do this with Command-C and Command-V. Am I doing something wrong or is this just a bug?
    Macbook Pro 13" 2.8GHz
    OS X Version 10.9.5
    -Rob
    iMac 27" Retina 5K 2017 4.2 GHz Intel Core i7 - 64 GB RAM Mac OS 10.14.6 Media Composer Version 2019.12.1 BMD Ultrastudio Mini Monitor [view my complete system specs]
  • Tue, Jan 20 2015 10:34 PM In reply to
    • PIC Agency
    • Joined on Tue, Jan 20 2015
    • Posts 3
    • Points 45
    Re: Command-C Copy doesn't work in columns
    bump
    similar issue here:
    http://community.avid.com/forums/t/132009.aspx
  • Sat, Jan 24 2015 1:30 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,746
    • Points 61,900
    Also on the PC side. Pain in neck.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Jan 26 2015 8:23 AM In reply to
    • Mark33
    • Joined on Mon, Jan 26 2015
    • Posts 8
    • Points 130
    Having this same issue with 8.3. It has really slowed down the multigrouping process which means we cannot yet upgrade to this version.
  • Tue, Jan 27 2015 6:21 PM In reply to
    Good news for people with this issue. A very helpful young lady at Avid sent me this "A fix is actually being worked on at the moment for the copy/paste issue" today.Yes
  • Tue, Jan 27 2015 7:57 PM In reply to
    Thanks Andrew. We are planning to get it into 8.3.1. If that changes, I will let you know.
    - Christie
    Christie Carr
    Sr. Software Quality Assurance Engineer
