Latest post Tue, Dec 16 2014 10:07 PM by Felix450. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Dec 16 2014 8:00 PM
    • Felix450
    • Posts 3
    • Points 25
    Application Manager Startup Issue - fails to launch
    Hello,
    Today i booted up my Avid and the I recieved an application error saying the following.
    "There was an error initialzing the licensing engine. If you have migrated data from a different Machine please delete folder: C:programData\Avid\ Licences" Application can't continue work and will be terminated."
    Also, when I start my avid It is now asking for a re-registration/ log in.
    This was surprising because last night the system was working fine.  I searched my folders and that file path does not exist on my computer.  There is a  file path of  "Program Files (x86)\Avid\Licenses\Avid\Avid Application Manager\License.pdf"
    I tested by removing the licsenses fodler but then the Application Manager does not launch and asks for a file path containing the installation pagage 'Avid Application Manager.msi'
    What can I do to fix this issue and get my avid running again without registration issues?
  • Tue, Dec 16 2014 10:07 PM In reply to
    • Felix450
    • Posts 3
    • Points 25
    Re: Application Manager Startup Issue - fails to launch
    Hello fellow Avid Users  -  Since Avid is very slow to respond to it's users issues unless you pay their $ fee for customer service.
    Here is the solution:
    For Windows Users:
    1)The program data file is hidden by default. Go to start and type " %programdata% " (without the quotations).  then hit return.
    2.)The window will then appear.  When re-launching Avid and the following message appears.
    Then delete the file.  The application manager should open properly.
    For Mac Users
    1. Quit avid completely
    2. In Finder, go to /Library/Application Support/Avid/Licenses
    3. Delete the licenses folder
    4. Now try starting avid again, and you should now be able to activate
