Latest post Thu, Dec 11 2014 9:51 AM by OleksiiK. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Dec 11 2014 5:35 AM
    • Vijeta
    • Joined on Tue, Jul 8 2014
    • Posts 9
    • Points 135
    Info Required for AVID Decoder Settings for fetching full range YUV components for files with bitdepth greater than 8
    We currently use DNxHD SDK for decoding DNxHD content. DNxHD content of each bitdepth is downsampled to 8 bit.
    Currently before calling  SetInputOutputDataTypes  SDK API of AVID Decoder , we are setting UncompInfo structure with the below info:--
        colorSpace = CS_YCbCr_709;
        colorComponentOrder = CCO_CbYCrY_NoA;
        chromaSubSampling = CSS_4220;
        resolution = RS_FULL;
        signalStandard = SS_274M_I;
        componentType = CT_UCHAR;
        componentRangeType = CRT_VideoRange;
        rasterGeometryType = RGT_SignalStandard;
        bufferLineOrientation = BLO_Top_Bot;
        bIsAlphaPresent = kACFFalse;
        uncompressedBufferAlignment = 16;
        isAlpha0Transparent = kACFBool_Max;
    After this everytime decode API on a frame will return the YUV components with bit depth 8 only  irrespective of bit depth defined by DNxHD Profile.
    As per my understanding, in order to fetch the values of YUV components with bit depth for streams having bit depth more than 8 we need to set componentType to CT_SHORT, but after this change the SetInputOutputDataTypes  SDK API returns error code -7(means HDCodec Memory Allocation fails.). Do we need to set something else in order to support the files for bit depth greater than 8.?
  • Thu, Dec 11 2014 9:51 AM In reply to
    • OleksiiK
    • Joined on Mon, Dec 23 2013
    • Posts 25
    • Points 270
    • Avid Developer Moderator
    Re: Info Required for AVID Decoder Settings for fetching full range YUV components for files with bitdepth greater than 8
    Vijeta,
    CT_USHORT_10_6 is the component type you are looking for. It stores 10 bit values shifted 6 bits left. So this component type could be used for 16 bit destinations without any intermediate conversion. To obtain 10 bit integer value from the CT_USHORT_10_6 component type you should divide its unsigned 2 bytes value by 64.
    Oleksii.
