Latest post Tue, Dec 9 2014 6:29 AM by Mondo. 2 replies.
  • Tue, Dec 9 2014 12:33 AM
    AMA export failing intermittently
    We are getting failings trying to export to AMA (UK DPP export) using MC 7.0.4
    Frustratingly it's not consitently failing - just 3 out of four attempts!  We get same results exporting locally or to a shared.  It's (mainly) a single codec timeline, but it is complex - and everything is rendered.  I'm sure a video mixdown might be worth considering, but i'd rather find a solution that does not recompress the content and further delay this already extended process!  (after we have made the file we are often faced with modem like speeds to deliver due to bottle necks the other end!)
    If anyone has come across something similar my editor would really love to know any hints or tips.  He's already been playing multiple youtube playlists in the background to try and slow the process down, which he claims has helped his success rate - shame about his tatse in music though...
    Paul
    PC MAC ISIS Z800 Z400 MacPro MC / DS / Resolve [view my complete system specs]
  • Tue, Dec 9 2014 6:29 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Re: AMA export failing intermittently
    Paul that looks like a corrupt clip error. That could becaused by some kind of timeout to the stream while it is being decoded or it could actually be corrupt, although I would htink in that case you would be getting more consistent errors.
    Probably check you have all the correct AMA versions and check that the volume it is coming off is not being bottlenecked by other users..
    BTW a video mixdown does not necessarily "recompress" the content - yes it does go through one compression process BUT it does that anyway when you export to a codec. So provided you choose a codec native to Avid and then do an SAS export you are still only subjecting your media to one compression cycle. Video mixdown also gives you the option of QT ref if you are sending to another encoder. A video mixdown nearly always solves or allows you to pinpoint the media that is causing an issue.
    John
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Paul that looks like a corrupt clip error. That could becaused by some kind of timeout to the stream while it is being decoded or it could actually be corrupt, although I would think in that case you would be getting more consistent errors.
    John
