Latest post Tue, Jan 13 2015 9:28 PM by Marianna. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Nov 18 2014 10:27 AM
    • raphael
    • Joined on Sun, Jun 8 2014
    • Posts 23
    • Points 295
    Application manager : error code 5
    Hello,
    When i start my computer, a window appears. Has someone met this problem? i am on windows 7 64b and Avid MC 8.0.1 and don't have a dongle. Thanks for helping.
    Moreover, i can not start MediaComposer even in trial mode.
    Win 7 - MC8.1 - P8P67 REV3.1 - I7 2600k - 16GB Corsair - Geforce Gtx 560ti - Seagate Barracuda 1TB - WD Black 2TB [view my complete system specs]
  • Tue, Nov 18 2014 11:17 AM In reply to
    Re: Application manager : error code 5
    I had the same problem some time ago. Maranna helped me as follows:
    Look for the following folders:
    C:\ProgramData\Avid\SWL
    C:\ProgramData\Avid\Licenses\Pro_Editor
    If found, delete the files inside. DO NOT delete the folders.
    This solved the problem in my case.
    MB: ASRock Z390 Taichi Ultimate. CPU: Intel Eight Core i9-9900K/3600 16MB Cache, SATA Hard Disks Raid (2x4 TB), GPU 1200MHz. GC: Gainward RTX2080 Super... [view my complete system specs]
  • Tue, Nov 18 2014 11:37 AM In reply to
    • raphael
    • Posts 23
    • Points 295
    Thank you very much Roland. It has started my Mc back but unfortunatly in trial mode only.
    My licence is still deactivated. I have never succeded to activate online (it always fails to join the servor) and offline is not working either (even with the xxxxxxx.bin file method).
    I  contact support. But i can work for 30 days at least...
  • Thu, Nov 20 2014 8:26 AM In reply to
    • wmcole
    • Posts 589
    • Points 7,820
    I just ran into this problem, a few days ago.  I followed the fix recommended here and it worked.  After AppMgr started functioning normally, when I started MC 8.2 I simply had to re-select my activation mode (I'm still using the dongle) and everything was back to normal.  For software activation, you might have to first de-activate the license, then re-select activation when MC first starts after fixing the error code 5 issue.
    HP z840 dual 8-core; PCI slot 3, Creative SB X-Fi audio card; 32 GB Ram; 4 x 1 TB RAID 5 internal SATA Western Digital Caviar Green Media drives (appears... [view my complete system specs]
    wmc
  • Mon, Dec 8 2014 2:05 PM In reply to
    • Posts 11,311
    • Points 232,425
    Roland Achini:
    Look for the following folders...............
    This one works for one version only and there are multiple versions so you are best to call support if you encounter this issue...
  • Wed, Dec 10 2014 7:23 PM In reply to
    • PCDuncan
    • Joined on Mon, Jul 20 2009
    • Burbank, CA
    • Posts 37
    • Points 565
    I am having this exact problem and none of the proposed solutions are working. Have tried the recommended fix to the PACE service which worked for a while. When I did the delete files fix it let me reactivate as a temp license (should be permanent) and then immediately gave me error code 5 again. In addition, I find it impossible to contact anyone at Avid to help with this.
    Any assistance, even a phone number would be great. Thanks.
    Patrick
    Avid Media Composer v8.3; Windows7 Professional with SP1 64-bit; Intel Core i7 Extreme Edition 980X 3.33 GHz Six Core Socket LGA1366; Intel DX58SO Extreme... [view my complete system specs]
  • Thu, Dec 11 2014 2:10 PM In reply to
    Hi PCDuncan,
       Can you email me offlist please? Keith.Gerrard@avid.com
    Thanks!
    ~Keith
    Keith Gerrard
    CP Senior Video Beta Coordinator | P&S Creative Professionals 30 (Matthew Collins)
    Avid
    65 Network Drive
    01803 Burlington
    United States Of America
    keith.gerrard@avid.com
    m +1 (530) 237-4331
    Help drive the future direction of the industry.
    Join the Avid Customer Association
    Save the Date for Avid Connect 2015!
    April 10-12, 2015 Las Vegas
    - MacPro, 2.66 GHz, 14G RAM; OS 10.8.4; MC DX Nitris; ISIS 4.5 - MacBook Pro, 2.3 GHz i7, 8G RAM, ISIS 4.5 - z800 Xeon 2.93Ghz, 12G RAM, Win 7, DX Nitris... [view my complete system specs]
  • Thu, Jan 8 2015 1:04 PM In reply to
    • Pete Higgins
    • Joined on Thu, Jan 8 2015
    • Ireland
    • Posts 6
    • Points 70
    Hi Folks,
    I'm getting the exact same error as raphael
    I've tried reinstalling MC along with the application manager but I still get the Error Code: 5 notification. I can't use AVID at all (I'm on an annual Symphony option subscription on Windows 7) and I'm losing precious work time! I've been using the Application manager for 3 months and my current machine and the past year on another and this error has never cropped up.
    I'd appreciate any help!
    Cheers
    Pete
    HP Z420 - MC 8.3.1 - 64bit 8GB RAM - Intel Xeon E5-1650 v2 @ 3.50Ghz [view my complete system specs]
  • Thu, Jan 8 2015 1:08 PM In reply to
    • raphael
    • Posts 23
    • Points 295
    Hi Pete, i advise you to call Avid support who kindly fixed this but unfortunatly i didn't get the why and how yet.
  • Thu, Jan 8 2015 1:43 PM In reply to
    • Pete Higgins
    • Ireland
    • Posts 6
    • Points 70
    Thanks Raphael, a quick call to AVID support sorted the problem!
    For anyone who has the problem in the future (and much like Roland's explanation above) -
    Make sure to quit Application Manger through the task manager and then go to C:/ProgramData (you'll need to show hidden folders to first) and delete the following FOLDERS
    Avid/Licenses/Pro_Editor
    Avid/AppManager
    Avid/SWL
    Pinnacle/Pixie
    Application Manager should now start up fine and you'll just need to reactivate your software with your System I.D. and software activation key.
    Why didn't I just call support 4 hours ago!!
  • Fri, Jan 9 2015 1:08 AM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 299
    • Points 3,575
    Yes - I have seen this on my system.  I just click the X and it goes away.  Avid then runs normal.  It happens every now and then.  However I just upgraded so I have not been running 8.3 for for a significant amount of time.
    Symphony 2020.8 - Win 10 pro (1909),Gigabyte X299X with i9 10920X cpu, Quadro P2000, 64gig memory, 1TB NV ystem drive, WD 4TB, BM Min Monitor, 11.7 drivers... [view my complete system specs]
  • Tue, Jan 13 2015 7:10 PM In reply to
    • Russ
    • Joined on Fri, May 24 2013
    • Posts 15
    • Points 185
    I have just started to get this problem. Drill down to Library/ApplicationSupport/Avid/AppManager and all I have in there is a config.txt file.
    "FNCProcessPortNumber 1696"
    Not sure if this is the listening port for the application, seems a bit strange to me?
    Just want to obliterate the AppManager then I can re-license with my Dongle.
    Any ideas?
    Russ
    Mac Pro 8 core with 32Gig of memory 27inch TB display and Sharp UHD monitor Current favourite DSLR is Panasonic GH4 Pre-ordered Sony FS7 (waiting "uncomfortably"... [view my complete system specs]
  • Tue, Jan 13 2015 9:28 PM In reply to
    • Posts 11,311
    • Points 232,425
    Hey Russ et al....
    I just explained that to the mod squad yesterday.
    Depending on the platform you have you will need to remove the following folder:
    Note: This applies for both Application Manager and Avid License Control utilities in all versions between 6.x to  8.x.
                       PC -  Look for the following folders.  If found, delete the entire folder.
                       Mac - Look for the following folders. If found, delete the entire folder.
                                 Macintosh HD/Library/Application_Support/Avid/Licenses
    Important:   If you can’t find the specific folder in Windows, go to Folder Options in the Tools menu and select “Show Hidden Folders.”
    HTH
    marianna
