Latest post Thu, Nov 6 2014 9:34 AM by Nikolai H. 0 replies.
Page 1 of 1 (1 items)
  • Thu, Nov 6 2014 9:34 AM
    • Nikolai H
    • Joined on Tue, Nov 27 2012
    • Norway
    • Posts 20
    • Points 265
    Relinked clips showing up as AMA-linked clips
    I imported some clips and transcoded to the DNxHD 185 codec.
    I needed to change these clips to DNxHD 85 for the edit, as they wouldd't playback realtime in a multicam window.
    I imported the same files again as DnXHD 85 in an other bin, and relinked the original clips. The relink process worked fine, they are all relinked, and the multicam and the separate clips are playing fine.
    However, some of the clips have the AMA-linked icon next to them, even though they are listed as having the DnXHD 85 codec. When I clip reveal file, the correct DnXHD file is showing up in Avid MediaFiles folder.
    Why are they showing up as AMA-linked files?
    edit: turns out, the video file is relinked to the correct file, but the audio is relinked to the AMA file. Not a huge issue, as we are not using the sound from the video files.
    But how do I make sure the sound is relinking to the correct clip?
    HP Z420 3.60Ghz 16GB RAM. [view my complete system specs]
    Filed under: ,
