Latest post Thu, Oct 9 2014 2:26 PM by Kevin Klimek. 2 replies.
  • Wed, Oct 8 2014 7:06 PM
    • rebusfilm
    • Malmo, Sweden
    • Posts 312
    • Points 3,900
    ProRes Color Levels RGB/709 inconsistency
    Usually I export DNxHD 185x from Avid and I always use Color Level RGB since i find that is the best way to get it in and out of After Effects, Nuke and Resolve and for compression in Squeeze.
    But today I was unsure if the producer had any Avid codecs installed on his computer so I exported a Quicktime ProRes HQ with Color Level RGB thinking it would yield the same result. It did not. I got crushed blacks and clipped whites in Quicktime Player and current AE.
    I then exported using Color Level 709 and this time the file looks identical to a DNxHD 185x using Color Level RGB. Confusing and very inconsistent behaviour, to say the least.
    To complicate things:
    A video mixdown of the sequence as ProRes HQ and an export using same as source with Color Level: RGB creates the same result as a ProRes HQ 709 without selecting same as source.
    This means that deselecting the Same as Source checkbox and exporting the exact same essence will create completely different color levels in the Quicktime..
    Should I consider this a bug or is it still supposed to be this difficult to get proper levels in and out of Avid.
    I am on MC 7.0.3
    TL;DR
    DNxHD 185x | RGB = Correct Levels
    ProRes HQ Mixdown | Same as Source | RGB = Correct Levels
    Inconsistent behaviour:
    ProRes HQ | RGB = Crushed Blacks and Clipped Whites
    ProRes HQ | 709 = Correct Levels
    Avid Media Composer 2020.4 | Mac Pro 7,1 | 16 core | 192 GB RAM | Radeon Pro Vega II | QNAP TVS-872XT | Decklink 4k Mini Monitor | Sony PVM-A250 OLED [view my complete system specs]
    Jorgen Persson
    Filed under: , , ,
  • Wed, Oct 8 2014 8:22 PM In reply to
    Re: ProRes Color Levels RGB/709 inconsistency
    If you choose a Custom codec when exporting from MC, you are essentially using QT Pro as the encoder. QT codecs fir H264 and ProRes are very prone to gamma issues. It's also slow, as it is 32bit.
    If you want to preserve color levels, transcode or mixdown your sequence to ProRes _inside_ MC, then export Same As Source.
  • Thu, Oct 9 2014 2:26 PM In reply to
    QuickTime tends to auto-adjust ProRes files so they appear RGB even if they are exported 601/709.  That's why the mixdown suggestion is the way to go.
