Latest post Tue, Sep 23 2014 8:40 PM by Job ter Burg. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Sep 23 2014 3:54 AM
    Changing Avid Aspect Ratio
    How do I change the Aspect Ratio for my Avid Project? I have black bars on the left and the right. I can't go from 16:9 to 4:3 as it is blured out as I right click. Did I make a mistake when I imported my video? Do I have to re-import everything or can I change it midstream?
    Filed under: ,
  • Tue, Sep 23 2014 6:48 AM In reply to
    Re: Changing Avid Aspect Ratio
    What is the actual geometry and aspect ratio of your footage?  What project type did you choose?
    (wwld)
  • Tue, Sep 23 2014 5:27 PM In reply to
    The original file was an .mpeg converted to a .mov and the resolution is 720 by 480. In Avid, I set the Project type as 1080p/29.97, Aspect Ratio is 16:9 which means there are black bars on the right and left side, but the screen isn't stretched, but the resolution of this project rendered comes out to 1920 by 1080.
    I try to change the project type to 720p/29.97, and there is no change.
  • Tue, Sep 23 2014 6:43 PM In reply to
    There is no 4:3 in HD. So you would need to switch to an SD project (which would also match your source footage's canvas size).
  • Tue, Sep 23 2014 6:53 PM In reply to
    How do I switch to an SD Project? Does this mean I have to start a new project and import the file into Avid again? That is going to take forever. The footage with the black bars on the side looks fine, the video ratio look good and it is not stretch. I was just wondering how to get rid of the black bars on the side.
  • Tue, Sep 23 2014 6:56 PM In reply to
    Robert Perrett:
    you can go to the format tab on the project window and choose SD. No need for a re-import
    Robert Perrett:
    it has applied a reformat effect.  you can change the reformat from pillar bars to allow you to zoom in, or use the frame flex to zoom in on your 4x3 footage to occupy the 16x9 aspect ratio.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Tue, Sep 23 2014 6:57 PM In reply to
    You should be able to switch the project format to NTSC 30i.
    There is no way to get rid of pillarboxing once it is encoded into the source file, as you have done. If you did a File->Import, then you're looking at a re-import.
  • Tue, Sep 23 2014 8:22 PM In reply to
    How do I crop the black bars and turn into a background under the video? I don't want to re-import, and have to redo the project just to get the right aspect ratio. I didn't know that is so important before I started.
  • Tue, Sep 23 2014 8:40 PM In reply to
    Add a Picture-In-Picture effect, set the scale from 50 to 100, use the Crop paramaters to crop the L and the R. Place on V2, place background on V1.
