Latest post Tue, Nov 11 2014 4:12 PM by ck123. 3 replies.
  • Wed, Sep 17 2014 12:57 AM
    • Patrice Shannon
    • Joined on Wed, Oct 21 2009
    • Wash, DC & Sarasota, FL
    • Posts 17
    • Points 200
    Error when nesting color correction
    When I step into Animatte effect to access color correction nested inside I get an error message:
    cannot find V2 track.  It won't let me make any color correction adjustments. It says: there is no video on which to apply this color adjustment.
    workaround: I remove the animatte, adjust the color correction, then put the animatte effect back on the clip.
    Wonder if this is a bug, or I'm doing something wrong?
    Running MC 7 on a Mac, using TerraBlock networking.
    Many Thanks,
    Patrice
    MacBook Pro 17"Late 2011, OS 10.9.5, 2.5 GHz Intel Core i7, 16 GB 1333 MHz DDR3 SDRAM, AMD Radeon HD 6770M, Intel HD Graphics 3000 [view my complete system specs]
    Patrice Shannon, Avid, Premiere and Final Cut Pro Editor
    Washington, DC and Sarasota, FL
    www.shannonpost.com
  • Mon, Nov 10 2014 6:30 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 149
    • Points 1,880
    Re: Error when nesting color correction
    Seeing this as well on the PC with v7.0.4.1.
    HP zBook 17 G3, z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, Dell Precision 3430, Dell Precision 7810, Apple iMac i5 27-Inch (5K, Late 2015). 16GB... [view my complete system specs]
  • Tue, Nov 11 2014 12:11 PM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    You could try stepping into the effect before entering CC mode
    John
  • Tue, Nov 11 2014 4:12 PM In reply to
    • ck123
    • PA
    • Posts 149
    • Points 1,880
    Worked just fin in 6.5. Sometimes doing this results in Avid crashing, so bug.
