Latest post Fri, Oct 13 2017 12:11 AM by Jonathan Heywood. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Aug 12 2014 10:13 AM
    • johan
    • Joined on Fri, Dec 28 2012
    • dubai
    • Posts 94
    • Points 1,000
    avid isis 5000 hard disk drive
    Hello ,
    i need to change one of my hard disk drive , can i replace it with this one ??
    note : picture A the original one (AVID) must replaced picture B the new one.
    A
    HP z400,z420,z620,z640 , windows 7 pro 64 bit , avid isis 5000 , avid airspeed 5000/5500 , avid newscutter 10, avid inews server , avid command news server... [view my complete system specs]
  • Tue, Aug 12 2014 10:17 AM In reply to
    • johan
    • dubai
    • Posts 94
    • Points 1,000
    Re: avid isis 5000 hard disk drive
    B
  • Tue, Aug 12 2014 8:02 PM In reply to
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    No.
    You must use Avid drive with Avid firmware.
    Replacing an Avid drive with a non-Avid drive will not work.
    Dori
    90x Media Composer, 8x Symphony Nitris, 8x ISIS 5000, ,6x Pro Tools, 4x Assimilate SCRATCH Systems- Opus Post Production, ISRAEL. [view my complete system specs]
  • Wed, Aug 13 2014 6:35 AM In reply to
    • johan
    • dubai
    • Posts 94
    • Points 1,000
    Thanks in advance Mr Dori , one more thing this event error happens too many i don't know why ? can you please help me what does it mean ?
    and is there a scheduled maintenance (daily , monthly , yearly) for avid ISIS 5000 ??
  • Wed, Aug 13 2014 8:03 AM In reply to
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    Seems to be related to duplicate network address. are you using DHCP or manual address?
    have a look here for maintenence:
    http://avid.force.com/pkb/articles/en_US/compatibility/ISIS-5000-Maintenance-Best-Practices
  • Thu, Feb 23 2017 12:56 PM In reply to
    Dori,
    Just out of curiosity. Have you ever tried with an of the shelf Western Digital WD2003FYYS drive?
    Isis 5000/5500 is the only system that actually uses the LSI hardware raid controller and I would expect that it does not check for any special Avid firmware.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Thu, Feb 23 2017 6:11 PM In reply to
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    Don't do it.
    i have tested it on our lab system, it doesn't work.
    ISIS will not use drives that don't have Avid firmware.
    The LSI Raid controller 'maybe' don't care. but the ISIS software does care.
    I t will fail during a rebuild with an error.
    see here:
    https://drive.google.com/drive/folders/0B1i5Fb8W5KmLT2xPVGRMUE05eEU?usp=sharing
    these pictures are from the log of our test system and also from the ISIS user guide that indicate that there is a special led flash will apper if you will install an unapproved disk.
    Dori
  • Thu, Feb 23 2017 6:50 PM In reply to
    Hi Dori,
    Thanks for that screenshot. Good to know the drives are still Avid branded.
    Kalispera.
    Jeroen van Eekeres
  • Thu, Feb 23 2017 7:08 PM In reply to
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    Your welcome!
  • Fri, Oct 13 2017 12:11 AM In reply to
    Thank you! This saved me the trouble of testing out the theory. I have an off the shelf drive that matches exactly and was going to throw it in.
