Latest post Fri, Jul 18 2014 4:41 PM by usatraveler. 2 replies.
  • Fri, Jul 18 2014 1:51 PM
    • stewart
    • shevin
    • Posts 9
    • Points 105
    consolidate an ama sequence
    I have a sequence which incorporates both transcoded and AMA media (most of which is ProRes). All of the media is on a Lanshare. I want to consolidate the sequence's clips with 24 frame handles to a drive I can work with off-site.
    When I attempted it to do this, I got a few error messages and much of the AMA files did not get consolidated. I looked at the console and it mentioned a few AMA clips that were not consolidated, but others were also skipped.
    Do you need to transcode AMA media before consolidating a sequence?
    Mac Pro 2013 10.12.6 Media Composer 2018.11.0 [view my complete system specs]
    Filed under: , ,
  • Fri, Jul 18 2014 4:29 PM In reply to
    • Dan
    • Joined on Fri, Oct 28 2011
    • Posts 238
    • Points 3,055
    Re: consolidate an ama sequence
    I think you have to transcode AMA before you can consolidate.  If you select your sequence and transcode, there should be an option to only transcode the AMA clips, at least I think there's an option to do that.  If there is, transcode the AMA, then consolidate the sequence.
  • Fri, Jul 18 2014 4:41 PM In reply to
    It depends on what kind of AMA media.
    If it's an Avid-native format, such as ProRes, DNxHD, or anything else that's in the media creation options, you can consolidate.
    If it's not an Avid-native format, you must transcode.  AVCHD and other forms of H.264 are common examples of this.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.5, Avid Media Composer 2020.6 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
