Latest post Thu, Jul 24 2014 5:32 AM by dugmoore. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Jul 17 2014 4:21 AM
    • dugmoore
    • Joined on Sat, May 7 2011
    • Southeast Asia
    • Posts 145
    • Points 1,520
    Capturing HDV to MC 8
    I have some HDV footage to capture to MC 8, and I keep getting a "No input Signal" error.
    I'm on MC 8, 10.9.2, 3.4 GHz i5.
    The deck is a Sony GV-HD700/1. I have the HDVi cable running to Thunderbolt, with an adapter.
    The resolution for capture is HDVi 1080 MXF, and I have tried other resolutions...same error message.
    I have changed the deck configration from generic Pal to several other Sony deck configurations, still,the same error. Video and Audio are set to Host 1394.
    Still, whenever I go to set the Video and A1 & A2 settings on the capture panel, the No input Signal" error came up.
    I'm getting concerend that I will have to use FCP 7 to capture, which is a solution at least, but another step to go through when I would rather just take it into Avid.
    Has anyone had this same issue and found a solution with MC 8?
    Filed under: , ,
  • Thu, Jul 17 2014 6:26 AM In reply to
    Re: Capturing HDV to MC 8
    Have you selected a 1080i project with a raster of 1440x1080?
    Jeroen van Eekeres
    www.mediaoffline.com
  • Thu, Jul 17 2014 7:26 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Jeroen van Eekeres:
    Hi Jeroen, this is a statement widely spread and I think it actually origins from the Avid KB.
    Trying to correct it sometimes when I see it so here we go.
    With the introduction of the Avid 64 bits era and to be compatible with all third party units and not only with Matrox Avid removed the possibility to set projects as 1440 x 1080 when a third party unit is connected.
    Actually that doesn´t matter as they didin´t change the capture codec, it´s still the same HDV capture codec as forever, just a plain copying of bits from tape to system without changing anything.
    So, project settings 1920 x 1080 and selecting capture codec HDV is how it should be setup, I have heard of users that are removing their physical devices when capturing HDV but that isn´t necessary
    Tomas
  • Thu, Jul 17 2014 7:29 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    dugmoore:
    I strongly believe that the TB adapter is the problem, you need a firewire connection, as Apple have cancelled them out nowadays best bet would be an old PC lap or workstation
    Tomas
  • Thu, Jul 17 2014 8:34 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    mjolnarn:
    dugmoore:
    Some google links
    https://www.google.se/#q=hdv+capturing+tb+adapter
    Tomas
  • Thu, Jul 17 2014 10:35 AM In reply to
    A screenshot from my MC8 software only trial. AFAIK selecting the 1440x1080 raster is the only way to capture HDV through firewire. Maybe powering off the matrox and starting MC without it will bring up the option and make capture work.
    Jeroen van Eekeres
  • Thu, Jul 17 2014 12:02 PM In reply to
    • dugmoore
    • Southeast Asia
    • Posts 145
    • Points 1,520
    I will try that when I am back at the office in the morning, but I think I tried the 1440x1080 raster. Thank you for all of the replies and support!
  • Thu, Jul 17 2014 6:52 PM In reply to
    • Susi
    • London, UK
    • Posts 583
    • Points 6,700
    If it is the TB/FW problem and ports/cabling is a sticking point - there might be a daisychaining option, via external hard-drive. (Saved my embarassment the other day, with client showing up with miniDV tapes and not the right cable in the office...)
    Media Composer 2018.9.0 on 13" early-2015 Macbook Pro (OSX10.13.6) 3.1GHz Intel Core i7, 16GB 1867 MHz DDR3 Intel Iris Graphics 6100 1536 MB Gizmos... [view my complete system specs]
  • Thu, Jul 24 2014 5:32 AM In reply to
    • dugmoore
    • Southeast Asia
    • Posts 145
    • Points 1,520
    Sorry for the late reply. I solved the issue by daisy chainging an HDV deck with an older LaCie drive!
    Thank you Susi for the suggestion.
