Latest post Mon, Dec 4 2017 4:28 PM by Marianna. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • Thu, May 15 2014 10:28 PM In reply to
    Re: Avid FX in Media Composer v8?
    OK, heres the plan I will keep studing with Avid FX 6.4 and then upgrade to Boris Red when the time is right. Thanks Douglas. I am trying not to have to due the Adobe rental plan.
    MC Version: 2018.2 System: PC windows 7 Pro 64 bit, Workstation ATX mid Tower case, MSI Z87-G45 MBoard, 650 watt,Crucial M500 250GB SSD, Intel i7-4770K... [view my complete system specs]
    MC 8.4.5     Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface  Pro Tools MP
  • Thu, May 15 2014 10:39 PM In reply to
    • Posts 10,666
    • Points 223,900
    Here is a screen grab of Avid FX and Boris Red to show the difference between the two.
    A Logo and a name - that's all.
    Regards
    Douglas
  • Thu, May 15 2014 11:15 PM In reply to
    Good to know that after learning Avid FX, I can keep with the interface by using Boris Red. LIke this blog says,
    "workflow is best served by staying within the Avid Media Composer, Avid FX is a huge addition to my toolset."
  • Tue, May 20 2014 5:39 PM In reply to
    Update just released. Those who own Avid FX now can update to Boris Red 5.5 for $295.
    Owners of previous versions of Avid FX (now Boris RED), including the bundled version from Avid Media Composer, Avid Symphony, and Avid Newscutter can upgrade to Boris RED 5.5 for $295 (MSRP USD).
    http://www.borisfx.com/press/Boris-FX-Announces-Boris-RED-5.5-for-the-Avid-Product-Family.php?utm_source=enews&utm_medium=email&utm_campaign=borisred5.5
    Filed under: ,
  • Wed, May 21 2014 7:11 AM In reply to
    • flashavid
    • England
    • Posts 307
    • Points 3,800
    Ronald Czarnecki:
    The question is how long is this offer open ? I'm sure I read that Avid FX will continue to work, so no need to spend money just yet .. Unless this is a very limited time offer.
    edit, this is probably what I read on the KB:
    "A:  Sorenson Squeeze functions outside of Media Composer software, so a change in software versions will not affect its functionality. Applications that work within Media Composer (Boris Continuum Complete, Avid FX, and NewBlue Titler Pro) should still continue to function. Always check with the manufacturer of the third party application about software compatibility and testing prior to making purchasing decisions."
    So pretty vague using the word "should" !
    Ever feel like you are being played like an old violin?
    MC 8.9.2 Symphony - MacPro 2.66Ghz 12core 48GB ram - OS 10.12.6 - BM 4K Extreme - Sapphire pulse RX580 8GB -SSD boot - 3 x 2TB internal WD caviar black... [view my complete system specs]
  • Wed, May 21 2014 10:50 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,392
    • Points 17,185
    Ronald Czarnecki:
    Edit -- deleted for bad math!
  • Wed, May 21 2014 11:01 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    smrpix:
    Ronald Czarnecki:
    Optionally, you can "rent" 2.5 years of After Effects for the same price.
    I will cancel all my Adobe subscriptions at once and take that offer instead, could you please post me the link, 10 dollars / month, I want that
    Tomas
  • Wed, May 21 2014 11:22 AM In reply to
    • smrpix
    • Posts 1,392
    • Points 17,185
    mjolnarn:
    smrpix:
    Ronald Czarnecki:
    Oh man, I should never post this early in the morning.  Embarrassed  It's $20/month, got it backwards. (Still not a bad deal)  Apologies.  Let me see if I can still correct my earlier post.
  • Wed, May 21 2014 2:40 PM In reply to
    I was liking having Avid FX inside of MC but I guess for the same $295 you can do After Effects Transfer
     "New to Version 3, the Avid to After Effects workflow allows for direct import and translation of Avid AAF format files. "
    http://www.borisfx.com/XML-Transfer/
    Have to check that out.
  • Tue, Jun 17 2014 3:39 AM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,488
    • Points 17,595
    Ronald Czarnecki:
    You don't need XML Transfert.
    If you have After Effects CS6, you can use the option "Pro Import After Effect" to import your Avid AAF directly in After Effects.
    With CS5 or 5.5, you can use the now free Automatic Duck plug-in.
    Media Composer 2018.12.2 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Tue, Mar 14 2017 12:32 PM In reply to
    • worldwiser
    • Joined on Mon, Mar 12 2007
    • London, England
    • Posts 93
    • Points 1,270
    I've been torturing myself with this problem for ages. But I discovered that the latest version of Avid FX (ie 6.4) is still available on the Download Center. If you're running this version of AFX, it will work with Avid 8.8.
    I had 6.0.1 and Avid kept crashing when you tried to use the plugin. It doesn't anymore. That's all I wanted, to go on using the software I'd always used and effectively paid for with my previous Avid purchase. No need to upgrade and pay more cash for something that's perfectly fine as it is. And finally, solution found.
    Avid MC 2018.12.1; Intel i7 8086k 6 core 4.0GHz; 32GB RAM; Win 10 64Bit; QT 7.7.9; Nvidia Quadro M2000 4GB. Main/Avid/OS drive 500GB SSD / Media 2TB [view my complete system specs]
  • Thu, Nov 30 2017 11:48 PM In reply to
    How Can I get the serial for Avid Fx 6.4. I have a perpetual license of MC but Avid Fx require a serial to install it. Any thoughts any one?
    Cheers
  • Mon, Dec 4 2017 4:28 PM In reply to
    • Posts 10,666
    • Points 223,900
    Raul
    Did you check your MY Avid?
