Latest post Tue, Jul 15 2014 7:34 PM by matthewh. 3 replies.
  • Mon, May 12 2014 10:34 PM
    • doc_maker
    • Joined on Wed, Jan 16 2013
    • Posts 4
    • Points 70
    Keeping Avid Effects in a 4K Workflow using Resolve
    Hi Everyone,
    i've just shot, edited, and delvered an HD documentary and done the whoel workflow in Avid, Resolve, and Soreson Squeeze.
    My new documentary is going to be shot in 4K Black Magic Pro Res (because I want to a lot of reframing) and is going to be outputed at 2K widescreen resolution, 2048x858.
    For the simple things like reframing, I understand that all I need to do is do the effects in Avid and they will transfer with the AFF file to Resolve together with the original 4K footage by relinking to it.
    However, there are many effects in Avid that I'd like to take advantage of that require transcoding - such as Fluid Morph, for interviews.  I understand that the convnetional way to do this would be to transcode into a high res file for Resolve, but since I'm working with 4k footage this won't work.  Nor will brining the color timed footage back into Avid to apply the effects because I need to finish in 2048x858 and Avid will only work in 1080p.
    Is there some way of keeping these Avid effects?  Or do they need to be done in an online editor? And if so, which one?
    Thank you!
  • Tue, May 13 2014 11:10 AM In reply to
    Re: Keeping Avid Effects in a 4K Workflow using Resolve
    To be honest for a 2K output I'd finish in Avid at HD. 1920 to 2048 is only 128 pixels less.
    If you do want to retain true 2K then you have to rebuild those effects outside Avid in whatever finishing system you choose. Resolve is ok for soem things but not all so you may have to hand off your Avid guide to scratch, smoke, flame or similar.
    However this can introduce other issues. Like you may need to grade elements before effects are applied.
    You are going to need a carefull post supervision eye on the exact workflow to make that work.
  • Wed, May 14 2014 7:41 PM In reply to
    • Kyle
    • Joined on Tue, May 29 2012
    • Posts 135
    • Points 1,685
    You can create video mixdowns of all the effects in Avid at the highest possible quality and then not relink those clips in resolve. (Takes a bit of finagling with the settings to get resolve to let you do this, but it'll work eventually). I recall needing to import my aaf twice and on one go around relink and on the other not and it worked out. That was with version 9 and 10 is suppoed to be better. Did this recently for a project we released on youtube in 4k and you can't tell which shots originated as HD and which ones we graded from the 4k files. And since you're only intending to output to 2k anyway, I think you'd be fine.
  • Tue, Jul 15 2014 7:34 PM In reply to
    • matthewh
    • Joined on Thu, Oct 24 2013
    • NY
    • Posts 98
    • Points 1,075
    Ressurecting this older post (sorry) Just worked on a low budget feature where many of our shots again finished up at 1920x1080 for the same reasons. Yes it "will do" at a push, but really, where's the love Avid?
    OSX 10.14.6 - Media Composer 2019.12.0 iMac (Retina 5K, 27-inch, Late 2014), 4 GHz Intel Core i7, 24 GB 1600 MHz DDR3, AMD Radeon R9 M295X 4 GB [view my complete system specs]
