Latest post Wed, Jun 18 2014 12:15 PM by Jacob Marris. 7 replies.
  • Mon, Mar 31 2014 8:11 PM
    MC 6.5.4.2 AMA Transcode: STREAM_SIZE_EXCEEDED, className:ameBaseStream error
    I constantly get an error STREAM_SIZE_EXCEEDED while transcoding some AMA linked clips from a Canon 5DMIII. Always the same files are not working, some do. The following exception is thrown:
    throwing STREAM_SIZE_EXCEEDED from ameBaseStream::SetPosition
    Exception caught in APlayer::Play - Exception: STREAM_SIZE_EXCEEDED, className:ameBaseStream
    What I did:
    1. Link to AMA File (or Volume)
    2. Transcode to DNxHD 120, convert audio sample rate (48kHz) and bit depth (24) activated, target audio PCM (MXF)
    3. start transcoding
    What I tried to fix the problem but didn’t help
    • Repair Disk Permissions
    • There is plenty of space on the disk
    • Create new project
    • Create new user profile
    • Remove site settings
    • Uninstall MC 6.5.4.1 and install MC 6.5.4.2 (none of them worked)
    • Reset PRAM
    • Changed source and target file location from external to internal drive
    What did work:
    • Play AMA clip
    • File > Import clip and transcode it to DNxHD120
    • Convert Clip with Davinci Resolve and drag mdb into bin
    AMA_ListPlugins installed:
    AVCHD MSP Plug-In             Avid Technology, Inc.    1.3.2.6205
    AVCHD MVP Plug-In             Avid Technology, Inc.    1.3.2.6205
    QuickTime Plug-In             Avid Technology, Inc.    1.2.2.7150
    MSP_MXF Plug-In               Avid Technology, Inc.    1.9.2.7150
    MSP_SonyXDCAMEXMP4_64bit      Sony Corporation         1.5007
    MVP_CanonXF64                 CANON INC.               2.0
    MVP_MSP_ARRI_MXF              © 2011-2012 Hamburg Pro M
    AS-02 Plug-In                 Avid Technology, Inc.    1.1.1.7150
    RED R3D Plug-In (R3DSDK v4.3) Avid Technology, Inc.    1.8
    MVP_SonyXDCAMEX_64bit         Sony Corporation         1.5007
    SonyXDCAM_64bit               Sony Corporation         1.3031
    What else can I do? Thanks for any hints!
    gorbi
    MacBook Pro (Retina, 15-inch, Mid 2015), 2.8 GHz Intel Core i7, 16 GB 1600 MHz DDR3, AMD Radeon R9 M370X 2048 MB, OS X 10.14.6, AVID MC 2019.11 [view my complete system specs]
  • Tue, Apr 1 2014 6:33 PM In reply to
    • Vladimir
    • Joined on Tue, Apr 1 2014
    • Kiev, Ukraine
    • Posts 11
    • Points 125
    Re: MC 6.5.4.2 AMA Transcode: STREAM_SIZE_EXCEEDED, className:ameBaseStream error
    was same trouble with MC 6.5.4.1
    rollback to v6.5.4 fix this issue, but it for OSX 10.8.5
    MacBook Pro 15" 2014 OSX 10.11.6 MC 8.8 [view my complete system specs]
  • Tue, Apr 1 2014 10:50 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 395
    • Points 4,680
    I am seeing the same issue with MC Patch v6.5.4.1 for windows. I have logged a case with Avid Support, and hopefully this will be classified as a bug and fixed in a future point release.
    In my case, rolling back to MC 6.5.4 also fixed the issue.
    Dave
    "A very big network"
  • Fri, Apr 4 2014 5:21 AM In reply to
    Thanks a lot for the hints. Good to know that this is a common issue.
    So rolling back to MC 6.5.4 is the only solution .
    Lets hope that AVID fixes this bug, because I do not want to roll back to 6.5.4 which means rolling back OS X to 10.8 as well. I've already installed 10.9.2. If you heare anything, please let me know.
  • Tue, Apr 29 2014 11:08 AM In reply to
    any news about this issue?
    I have the same issue.
    Mainly the longer clips (bigger files) do not work.
    On supported Mac Pro with OS 10.8.5 and iMac with 10.9.1.
    With MC 7.0.3 I could not replicate the problem.
    But MC 7.0.3 is not the idiale solution in my case.
  • Tue, Apr 29 2014 3:05 PM In reply to
    • NYnutz
    • New York City
    • Posts 395
    • Points 4,680
    Support Video Data:
    Avid support is still working on my case, so nothing new.
    Dave
  • Wed, Jun 18 2014 9:20 AM In reply to
    Just had a customer call with the same problem. But he has his MC 6.5.4.2 activated with an MC 8 activation code so a roll back to 6.5.4 is not an option... or I need to request a MC 6.5 activation code.
    Avid... a fix?...Today for a change? Stick out tongue
    Jeroen van Eekeres
    www.mediaoffline.com
  • Wed, Jun 18 2014 12:15 PM In reply to
    • Jacob Marris
    • Joined on Sun, Mar 20 2011
    • Athens-Greece
    • Posts 14
    • Points 180
    Surprising enough to see that this is happening in a version that follows previous ones that don't have this problem. It is SUPPOSED that newer versions are BETTER than older ones, isn't this wright? … so guess according to this sort of revolutionary concept by Avid, the wright choice right now is to roll back at ver 2.8.3 and return almost 10 years back in the workflow process of NLE systems...Big Smile
    Currently all systems cannibalized due to some economical setbacks... but looking forward for a custom system based on an Asus Z9PA-U8 workstation board... [view my complete system specs]
