Latest post Mon, Mar 24 2014 5:59 PM by AndrewAction. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Mar 24 2014 3:52 AM
    • S.Clements
    • Joined on Sun, Jul 3 2011
    • London, United Kingdom
    • Posts 812
    • Points 10,775
    OMF Export Headaches: "Segmentation Fault" error on a couple isolated tracks
         I always have headaches when exporting OMFs for the sound department from my system.  AAFs export fine, but OMFs almost always cause crashes or errors of some sort.
         To prepare, I make my project SD.  I delete all video and effects and set Media Creation settings to OMF (even though I heard this isn't necessary).
         I try to export my sequence.  Eventually, I get an Alert Message: "Segmentation Fault" in thread "Main Thread", at address 0x0.  Avid crashes.
         I've isolated the problem down to two separate tracks.  I thought I'd isolated the file that might have been corrupt (although it plays fine), so I reimported it and tried again.
         I still got the same error.  I've tried fixing the drive permissions, deleting the directory files, trashing the project and avid prefs, restarting and nothing works.  I've tried using a different user and a new project as well.  It's just being a stubborn track.  It won't export to OMF.  Does anyone have any ideas what could be causing this and how I can actually get an OMF to the sound designer?  Unfortunately, he's using Logic, which doesn't accept AAFs.
    Avid Media Composer 8.3.1 Macbook Pro (Retina, 15-inch, Mid 2014) 2.8 GHz Intel Core i7, 16GB Ram Mac, OS 10.10.2 [view my complete system specs]
  • Mon, Mar 24 2014 7:32 AM In reply to
    Re: OMF Export Headaches: "Segmentation Fault" error on a couple isolated tracks
    You could try making a new empty sequence with the same start time as your sequence. The same number of tracks as your existing timeline. Then add 1 more track the same type as your problem track. Then edit the old sequence into the new sequence patching the problem track to the new "extra" track you just created.
    My guess would still be that Avid is remembering a rogue frame or render that does not match the OMF file requirements.
  • Mon, Mar 24 2014 11:04 AM In reply to
    • S.Clements
    • Posts 812
    • Points 10,775
    AndrewAction:
    Thanks, Andrew. Unfortunately, making a new sequence and following the procedure you outline did not work.  I also tried clearing all renders.  I keep getting the same error and crash.  I'm not sure how to solve this problem.
  • Mon, Mar 24 2014 11:35 AM In reply to
    From what I know of the segmentation fault error, it's a pretty generic one.  In case you haven't already, I'd do a Google search for "segmentation fault media composer" and then look through the results from the forum and from the knowledge base for any that match what you're seeing.  Sorry I don't have a better answer.
  • Mon, Mar 24 2014 2:14 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,775
    Hi, Cam.  Thanks for the suggestion.  I couldn't find anything of help.  One small breakthrough I've made is that I've discovered I can export OMF 1.0, but not 2.0.  I'm not sure if that will be a problem.  I'm waiting to speak to the sound designer.  I've read that OMF is more compatible across the board, but so far that's all I know about the differences between the two formats.  Hopefully Apple Logic accepts OMF 1.0
  • Mon, Mar 24 2014 5:59 PM In reply to
    S.Clements:
    In this case yes.
    FWIW here OMF 1 worked originally when it was first releasd but it was marginal.  OMF2 was a vast improvement and worked well here for years.  AAF was then another great improvement on OMF
    All these findings are based on Avid to Protools workflows and I started using OMF 1's before Avid brought DigiDesign - Protools)
