Latest post Mon, Apr 14 2014 8:00 AM by Siddharthan.K. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Mar 18 2014 11:19 PM
    • nuclearpicnic
    • Los Angeles, CA
    • Posts 200
    • Points 2,585
    7.0.3 really buggy
    I'm having some crazy issues with 7.0.3... I can't create a freeze frame from the menu.  nothing happens.  I found a workaround by creating a button for freeze frames instead... that works... also having issues rendering in to out.. all rendering choices are greyed out under the clp menu but again, a button can do it.  Anyone else seeing weird stuff like this?
    Mac Pro 2009 Quad Core, Media Composer 8.7 AJA IoExpress, Avid Artist Mix, Sonnet PCI Express 2-Port eSATA, 32Gb Ram, HP displays, keyspan. Drobo S for... [view my complete system specs]
  • Wed, Mar 19 2014 3:55 AM In reply to
    Re: 7.0.3 really buggy
    What OS?
    Most are New MacPro 12 core or 8 Core 2012 MacPros with 24+ Gb Ram nvidia gtx 1070 [view my complete system specs]
  • Wed, Mar 19 2014 4:55 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,694
    • Points 44,430
    Have you tried creating a new user? Sonds like there might be something corrupted.
    Good luck,
    Jef
    Jef Huey
  • Wed, Mar 19 2014 9:09 AM In reply to
    • buchel
    • Joined on Wed, Mar 15 2006
    • Cologne, germany
    • Posts 64
    • Points 750
    just a side note. Instead of creating a freeze frame you could apply a timewarp effect with 0% speed.
    Cheers
    40 workstations HP and DIY, WIN 10 64bit MC 2018.12.3 Elements Shared Storage 720TB Arista 40GbE Backbone, 10 GBaseT Clients. Editshare shared storage... [view my complete system specs]
  • Wed, Mar 19 2014 7:53 PM In reply to
    • nuclearpicnic
    • Los Angeles, CA
    • Posts 200
    • Points 2,585
    thanks all... OS is 10.9.1
    this user setting was built from scratch on this system...
    I'll try creating another one...
  • Fri, Mar 21 2014 11:03 AM In reply to
    HI
    I have the same problem, nothing happens when i click freez frame, and I cant change fields order, it is stuck on the topp one.
    I tryed a new user, no help.
    Any other suggestions?
    Regards
    Emil
    I am on Macbook Pro 10.9.1
    AVID MC 7.0.3, Macbook Pro, Retina, Mid 2012, 2,3 GHz Intel Core i7, 8 GB 1600 MHz DDR3, NVIDIA GeForce GT 650M 1024 MB, OS X 10.9.1 [view my complete system specs]
  • Fri, Mar 21 2014 3:33 PM In reply to
    What is the material (type of footage) you're trying to make a freeze frame for?  It has to match the current project's settings or you'll have to use a timewarp effect.
  • Fri, Mar 21 2014 3:43 PM In reply to
    • nuclearpicnic
    • Los Angeles, CA
    • Posts 200
    • Points 2,585
    my footage matches the project settings.  and I CAN create a freeze frame from the button I created, just not from the menu.
  • Fri, Mar 21 2014 3:48 PM In reply to
    same thing here.
    I can use a button to create freez frame but not from menu.
    same setting for footage and project,
  • Fri, Mar 21 2014 7:28 PM In reply to
    • nuclearpicnic
    • Los Angeles, CA
    • Posts 200
    • Points 2,585
    created new user settings, deleted media composer preferences from user library... still the same issues.
  • Sat, Apr 12 2014 1:45 PM In reply to
    I dont have the problem anymore, an I dont know what was wrong.
    /emil
  • Sun, Apr 13 2014 5:54 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,320
      Moderator: MCA Mac
    Was it a grouped clip?  You need to hit the match frame button again to get to the individual clip as grouped clips can't be freeze framed.
  • Sun, Apr 13 2014 6:44 PM In reply to
    • nuclearpicnic
    • Los Angeles, CA
    • Posts 200
    • Points 2,585
    no. it wasn't a grouped clip, it was a master clip... if it was a grouped clip, I wouldn't have been able to do the effect with the button I created, would I?
  • Mon, Apr 14 2014 8:00 AM In reply to
    HI
    There is no direct out option for audio in MC 7.0.3Sad
