Latest post Fri, Mar 7 2014 12:53 AM by Jeremy Deneau. 3 replies.
  • Thu, Mar 6 2014 2:30 AM
    copying proj and mediafiles
    I have a project on a drive that is starting to fail. The drive I need to copy has a mediafiles-MXF-1 already. I am new to MC and have not had to do a transfer of this kind before.
    Thanks in advance for the help.
    iMac Mid 2013 27", Mac OS X 10.9.5, Avid Media Composer 8.3.1, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX 680MX 2048 MB [view my complete system specs]
  • Thu, Mar 6 2014 5:53 AM In reply to
    • PegasusNZ
    • Joined on Mon, Jul 10 2006
    • Auckland, New Zealand
    • Posts 330
    • Points 3,935
    Re: copying proj and mediafiles
    Copy your Media to a new drive Avid Mediafiles/MXF/1 or replace 1 with any number if there is already media on that drive
    If your project is on that drive also then copy that off to the new drive
    in your new Avid MediaFiles/MXF/# delete the 2 database files
    When you start Avid the database will be rebuilt and Avid will find the media on the new drive
    HTH
    8 x Z800 24GB RAM MC 7 Black Magic Decklink Studio 240TB Linux Server [view my complete system specs]
    ^^ A good edit takes time but who has the time? When I look back I see my mistakes!
  • Thu, Mar 6 2014 9:38 AM In reply to
    If you copy the entire contents of a numbered MXF folder and don't change any of the contents inside that folder the database files (that start with MSM) should work fine without being deleted and rebuilt.
    If you don;t see the expected media then delete those MSM files and let MC re-build them.
  • Fri, Mar 7 2014 12:53 AM In reply to
    Thanks. Copied the "1" folder, renamed it "2" and worked fine.
    Thank you both for the help.
