Latest post Sun, Jun 15 2014 1:23 PM by johan. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Feb 26 2014 9:08 AM
    • johan
    • Joined on Fri, Dec 28 2012
    • dubai
    • Posts 88
    • Points 940
    avid isis 5000
    Hi all,
    i have an issue with deletion ?
    Recently i delete bins which contains clips about 50 bins from avid newscutter PC , then I checked my storage management in avid ISIS 5000 free space available still the same size !
    These 50 bins equal minimum 8 TB size ? why avid ISIS 5000  did not delete files ?? thank you.
    HP z400,z420,z620,z640 , windows 7 pro 64 bit , avid isis 5000 , avid airspeed 5000/5500 , avid newscutter 10, avid inews server , avid command news server... [view my complete system specs]
  • Wed, Feb 26 2014 4:34 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,265
    • Points 27,965
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: avid isis 5000
    Did you delete the bins or clips? You need to delete the clips in the bin from within NewsCutter. When you delete the clips a dialog should open asking if you'd like to delete the media.
  • Thu, Feb 27 2014 6:27 AM In reply to
    • johan
    • dubai
    • Posts 88
    • Points 940
    Re: avid isis 5000
    thank you for reply,
    No i delete all the bins not clips , so i must delete it manually from storage files right ?
  • Thu, Feb 27 2014 2:28 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,265
    • Points 27,965
    Re: avid isis 5000
    Within Media Composer, open the Tools > Media Tool. Select the workspace(s) where the media is located and the All Projects button; you must press the button and not shift select the projects that show up.
    On the bottom of that dialog select Master Clips and Precompute Clips, don't select Media Files.
    A bin will open with all the media in it and you'll be able to selectively delete it.
  • Wed, Jun 11 2014 9:39 AM In reply to
    • johan
    • dubai
    • Posts 88
    • Points 940
    Re: avid isis 5000
    Dear Bob russo,
    Thank you very much , but do you have any suggestions for this error in my ISIS 5000 storage ?
  • Wed, Jun 11 2014 5:13 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,265
    • Points 27,965
    Re: avid isis 5000
    It looks like the drive controller detected a failed drive (read time was 7 seconds) and swapped the global hot spare drive into the RAID set. The failed drive should have both the blue and red LEDs on solid and should be replaced ASAP.
    It looks like you're running 4.0.0. This is a very old version and once you've replaced the global hot spare I strongly recomend that you upgrade to the current version of ISIS.
  • Thu, Jun 12 2014 6:07 AM In reply to
    • johan
    • dubai
    • Posts 88
    • Points 940
    Re: avid isis 5000
    yes i need to replace the hard disk drive immediately blue and red LEDs on solid , Dear bob russo can i update my avid isis5000 version  4.0.0.5500 to 4.6.1.1 without any problem (license , compatibility,etc..) ?? and if i can please send me any related files or documnets for how to upgrade my avid isis 5000 ? i will be very thankful.
  • Fri, Jun 13 2014 2:51 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,265
    • Points 27,965
    Re: avid isis 5000
    To replace a drive look at the Avid ISIS 5500 | 5000 Setup Guide v4.6. Chapter 8, Page 133.
    The software is availabe on the Avid Download Center.
    If you're not completely comfortable doing this, I encourge you to hire an ACSR.
  • Sun, Jun 15 2014 1:23 PM In reply to
    • johan
    • dubai
    • Posts 88
    • Points 940
    Re: avid isis 5000
    Thank you very much
