Latest post Tue, Feb 4 2014 11:34 AM by Pat Horridge. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Feb 3 2014 5:41 PM
    • thomasz
    • Joined on Mon, Feb 3 2014
    • Posts 1
    • Points 15
    media compioser 7 problems quality import
    HI,
    I'm new on media composer 7 and have a few problems to import or AMA link my videos.
    Indeed I can import them, but their resolution in media composer is bad. It's like if a grey filter was put upon them on the software. The colors are less intense.
    I try to change my bin stting, or to change my profil options... nothing changes. The quality is a bit better in AMA link though but still isn't like my videos outside of the software.I also try to go in the options when I do my import but I'm lost.
    My originals files orin 1920*1080. In apple Prores 422. HD 1-1-1 and  in .mov.
    Could someone help me with directions please ?
    Best.
    Thomasz
    Filed under: , , ,
  • Tue, Feb 4 2014 11:34 AM In reply to
    Re: media compioser 7 problems quality import
    When you import try changing the import settings to computer RGB rather than 601/709 levels.
    But you need to check the imported files then have thje correct levels.
    MC is designed to work with 601/709 levels and that means the digital value of black at 8bits is 16 not 0 as it is in RGB levels.
    So your source record monitor will look washed out. Normally you'd have a 3rd output monitor on HD-SDI or HDMI and that would be calibrated for a 601/709 signal and would show the signals correctly.
    So it may just be you are judging using the source record viewers and they aren't represntative.
