Latest post Thu, Jan 23 2014 4:29 PM by Randall L. Rike. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jan 23 2014 4:20 PM
    • Ivan Kowalenko
    • Joined on Thu, Jan 10 2013
    • Minneapolis, MN
    • Posts 7
    • Points 95
    MC7 Bug: Opening .AVP files with the Select Project window up will open the project, but not dismiss the Project window
    I've found that if I fire up Media Composer 7, and then open my project file (AVP file) from The Finder, that it will indeed load the project, but not dismiss the Select Project window, leaving me stuck in a weird limbo, where the project is open, but inacessible because the Select Project window hasn't been dismissed. So far the only way out of that situation that I've discovered is to outright quit Media Composer, and start over.
    I've seen this happen on a couple different machines. Anyone else run into this issue?
    System specs:
    • Media Composer 7.0.2
    • Mac OS X 10.8.6
    • Various Mac Pros
    Various Mac Pros, ranging from MacPro2,1 to the last of the big 'ole towers. [view my complete system specs]
  • Thu, Jan 23 2014 4:29 PM In reply to
    Re: MC7 Bug: Opening .AVP files with the Select Project window up will open the project, but not dismiss the Project window
    I'm confused, if you've launched MC, why launch an .avp from the finder level, rather than through the Project Selection Window?  Personally, I wouldn't expect that to work ciorrectly Hmm
    (wwld)
