Latest post Thu, Jan 16 2014 8:38 AM by mjolnarn. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jan 14 2014 7:05 AM
    • PegasusNZ
    • Joined on Mon, Jul 10 2006
    • Auckland, New Zealand
    • Posts 330
    • Points 3,935
    Exporting a MXF OP1a XDCAM VBI Noise
    Hi
    I am exporting programs for a broadcasters as MXF OP1a XDCAM files and are getting noise in the VBI. first few programs were fine but then came this random noise on the bottom after where the VITC would normally be
    Broadcaster won't accept the files so any help apperciated
    Cheers
    Callum
    8 x Z800 24GB RAM MC 7 Black Magic Decklink Studio 240TB Linux Server [view my complete system specs]
    ^^ A good edit takes time but who has the time? When I look back I see my mistakes!
  • Wed, Jan 15 2014 9:55 PM In reply to
    • PegasusNZ
    • Posts 330
    • Points 3,935
    Re: Exporting a MXF OP1a XDCAM VBI Noise
    Update this only happens when exporting an SD clip
  • Thu, Jan 16 2014 5:08 AM In reply to
    • PegasusNZ
    • Posts 330
    • Points 3,935
    Just in case anyone else suffers this the VBI Noise only occurs in SD 1:1 footage simply mixdown your sequence to 2:1 and it is fixed
  • Thu, Jan 16 2014 7:08 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    I suppose you are working with Pal footage Callum, is that so.
    Tomas
  • Thu, Jan 16 2014 7:56 AM In reply to
    • PegasusNZ
    • Posts 330
    • Points 3,935
    Yes it happens in PAL but I would guess it happens in NTSC as well
    I was incorrect when I said just change resolution, DV 420 works all the time 2:1 sometime has some disturbance
  • Thu, Jan 16 2014 8:38 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    PegasusNZ:
    Not quite sure about that, I can remember some old Pal 1:1 SD bugs, most of them fixed by now but there might be some of them still present.
    Tomas
