Latest post Mon, Mar 16 2015 11:14 AM by MikeyB. 4 replies.
  • Fri, Dec 20 2013 6:04 PM
    • apmende
    • Posts 30
    • Points 500
    Toggle from Bin Window to Source Monitor
    Is there a shortcut key or key that I can map that will let me toggle between the bin window and the source monitor?  I hate that I have to physically use the mouse to get back to the bin from the source monitor.
    Thank you Avid Gods in advance.
  • Fri, Dec 20 2013 8:01 PM In reply to
    • Darren
    • Joined on Tue, Jun 25 2013
    • Toronto
    • Posts 16
    • Points 240
    Re: Toggle from Bin Window to Source Monitor
    I'm not sure if you can go to a certain bin easily, but (CTRL)command + 4 will bring you to your composer window, esc will toggle through source and record monitors.
    Quick edit, just remembered (CTRL)command + ~  (The botton beside 1) will toggle through bins, and timeline, and such.  That's probably what you're looking for.  Not as quick though.
    Assistant Editor
  • Fri, Dec 20 2013 8:27 PM In reply to
    You can use command-~ (or I guess CTRL-~ on Windows) to switch to the most recent window. So activate the bin you want to switch back to, then press command-4 to bring up the source monitor, then press command-~ once to switch back to the bin. Repeat.
    Now, if only there were a keyboard shortcut to edit the name of a selected clip in a bin, I could do totally mouse-less logging.
  • Sun, Mar 15 2015 10:55 PM In reply to
    • filmfriseur
    • Joined on Fri, Feb 8 2013
    • Berlin, Germany
    • Posts 63
    • Points 560
    command-~    is not working for me. Any suggestions? Can it be, that I use a german keyboard for mac?
    amc 2018.4 - symphony . 3.46 dual 6core mac pro (early2009, upgraded to westmere 5.1, OSX 10.12.6). 64 gb . msi gtx 970 . 2x 27" monitor . 1x 24"... [view my complete system specs]
  • Mon, Mar 16 2015 11:14 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 485
    • Points 6,030
    Yes, Cmd/~ takes you from the Bin to the Source Monitor, but getting back is trickier. What about using Find Bin to take you back to the same bin the clip is in?  You could map it to a spare keyboard key.
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
