Latest post Wed, Nov 20 2013 4:26 PM by BobbyMurcerFan. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Nov 19 2013 7:59 PM
    • S.Clements
    • Joined on Sun, Jul 3 2011
    • London, United Kingdom
    • Posts 812
    • Points 10,775
    Change Bin/Window Opening Behaviour
    The way bins and various windows open in Media Composer is very inconvenient and much time is wasted repositioning them around the place - especially on a laptop.  Media composer would be much nicer to use if bins opened in a neat, controlled way (as tabs or some other solution) rather than popping out infront of everything and requiring repositioning.  This is where FCP really shined...no time wasted rearranging windows and bins.  I've mentioned this in the forums before and the advice was to hook up another monitor to the laptop, as Avid really requires 2 monitors to work properly, however I feel that enough people are editing on laptops these days to warrant coming up with a better solution.  Also, saved custom workspaces only help with the problem to a certain degree.  The bottom line is that it's much more messy dealing with bins and windows in Avid than it is in other NLEs.
    Avid Media Composer 8.3.1 Macbook Pro (Retina, 15-inch, Mid 2014) 2.8 GHz Intel Core i7, 16GB Ram Mac, OS 10.10.2 [view my complete system specs]
    Filed under: , , ,
  • Wed, Nov 20 2013 1:17 PM In reply to
    Re: Change Bin/Window Opening Behaviour
    Hold Option (ALT on PC) when opening the project to prevent the Bins from automatically opening.
  • Wed, Nov 20 2013 1:32 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,775
    Kenton.VanNatten:
    Thanks, Kenton.  This actually isn't my problem.  It is the WAY the bins open - how they open up right out in the middle of the UI, instead of in a controlled unobstructive manner.  I would like a means of accessing bin material without having this behaviour which requires moving windows around.
  • Wed, Nov 20 2013 4:01 PM In reply to
    I'm not sure if it will do exactly what you need, but have you tried the save bin layout feature?
  • Wed, Nov 20 2013 4:13 PM In reply to
    • S.Clements
    • Posts 812
    • Points 10,775
    BobbyMurcerFan:
    Thanks, Bobby.  I currently work strictly on a laptop, where the save bin layout feature only helps me to a certain extent.  Maybe there is more I could do to make the feature work better for me, but I haven't discovered the right formula.  Bins are added throughout an edit, so layouts would have to continually be set up and saved.  I think bins should be able to be "twirled down" same as folders, for easier access to clips.  Maybe bins could have a smaller triangle beside them to twirl them open.
  • Wed, Nov 20 2013 4:26 PM In reply to
    I do agree that bin and window management in MC feels very clunky. And I miss the Superbin.
