Latest post Fri, Jun 20 2014 8:17 PM by mikela. 178 replies.
Page 2 of 12 (179 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Sat, Oct 26 2013 5:55 PM In reply to
    • oatbean
    • Washington DC area
    • Posts 130
    • Points 1,705
    Re: Mac OS X 10.9 (Maverick) | Support for MC, PT and Sibelius
    Oh... there it is! Thanks!
    For anyone out there curious... it's named "Install OS X Mavericks".
    MacBook Pro (Retina, Mid 2012) OSX Yosemite 10.10.3 2.7 GHz Intel Core i7 16 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB Mac MC 8.4.0 (software... [view my complete system specs]
  • Mon, Oct 28 2013 4:55 PM In reply to
    • ctomo1
    • Joined on Wed, Aug 15 2012
    • Posts 21
    • Points 245
    Hi Marianna or anyone on the Avid team,
    Sorry to try and dig for an answer, but in terms of weeks how long will it take to get a revised version out? We have new macs coming in now that won't downgrade to lower OS and therefore we can't use Avid.
  • Mon, Oct 28 2013 10:47 PM In reply to
    • Posts 11,268
    • Points 231,960
    We are working on testing it but have uncovered quite a few issues as outlined here:
    http://avid.force.com/pkb/articles/en_US/troubleshooting/Mac-OS-10-9-support-for-Media-Composer-Pro-Tools-Sibelius
    it is not a question of not wanting it to work - it is a question of it - wont until we fix some things and possibly Apple as well.
    M
  • Tue, Oct 29 2013 10:35 PM In reply to
    • NickScale
    • Joined on Thu, Apr 25 2013
    • Posts 22
    • Points 240
    I used DiskMakerX (formerly called LionDiskMaker) to create a bootable USB drive for installing 10.9 Mavericks on more than one Mac without having to redownload the installer.
    http://liondiskmaker.com/
    It was recently updated for Mavericks and the process worked on my 13" Macbook Pro 2010 which was on 10.8.5 before upgrading.
    Nick
  • Thu, Oct 31 2013 9:48 PM In reply to
    Ok, I'm confused. The only way I can get Mavericks is through the App store. When I click "upgrade" it changes to a green button that says "install". Should I click "install" or will that actually "install" the app? I know I've done this before but I can't remember specifically what happens because I was not paying attention - mostly because I wanted the app to actually install, so I just stepped away while it did!
    27" iMac 5k Retina 4 GHz Intel Core i7, 32GB RAM, AMD Radeon R9 M295X 4096 MB, OSX 10.10.5 Avid Media Composer 8.5.2 [view my complete system specs]
    Sean Dahlberg
    First and Last Films, LLC
    Writer/Director/Editor
  • Fri, Nov 1 2013 12:54 PM In reply to
    • kokomono
    • Joined on Tue, Oct 29 2013
    • Berlin
    • Posts 13
    • Points 150
    HI Marianna,
    Thanks for working on it...I got the same problem, just got anew Mac Pro...with Mavericks ;(
    So I tried to install MC 7, but it failed, in the very end of the process. Necvertheless the programm and so on are now on the computer. I did the installation after checking the Troubleshhoting page, there nothing was written that a installation wouldn't work (I thought I could live with the small bugs at the moment)
    Problem is: I tried to uninstall the failed installation, but this is not possible with the uninstaller.
    How should I proceed? Is this going to be a problem if there is a update later?
    Best,
    koko monoi
    MacBook Pro Retina 2,6 GHz Quad-Core Intel Core i7 16GB RAM [view my complete system specs]
  • Fri, Nov 1 2013 1:44 PM In reply to
    • andrejavid
    • Joined on Fri, Nov 1 2013
    • Posts 1
    • Points 5
    i have the same exact problem as kokomono! (with a macbook pro retina)
  • Fri, Nov 1 2013 4:25 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 1,589
    • Points 19,755
    Sean Dahlberg:
    And I have the same problem as Sean.  Apple is so quick to update all on its own these days.
    If we hit the "Install" button, can we rest assured that in fact Mavericks WON'T install, but will just sit quietly in our Applications folder waiting for further instructions (from us, not Apple)?
    thanks, Malcolm
    Mac Pro 6-Core 3.3GHz • OSX 10.9.1 • Media Composer v7.0.3 [view my complete system specs]
  • Fri, Nov 1 2013 7:58 PM In reply to
    mhamilton:
    Why not move it from the Applications folder to a foldfer of your choosing? Move back when you want to install. I do not know that this works but it is what I have done so I will find out when I get around to installing it (when approved by Avid of course)
  • Fri, Nov 1 2013 8:12 PM In reply to
    • kokomono
    • Berlin
    • Posts 13
    • Points 150
    @mhamilton
    Thats exactly what I did.
    If you click in the App Store, the donwload starts to your application folder...
    After the download is finished a window opens aksing you if you want to install.
    At this point you can quit the installer.
    Then you can take the installer out of the application folder.
    Once you want to update, just double click...
    mhamilton:
    thanks, Malcolm
    You should uncheck install app updates in the APP Store settings in System Preferences.That will stop the App Store from atomatically installing updates.
    Mac Pro 2014 6 core 32gb RAM / AJA 4K IO / MC 8.5.1 / OSX 10.10.5 Retina Macbook Pro (Mid 2014) [view my complete system specs]
  • Fri, Nov 1 2013 10:06 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 1,589
    • Points 19,755
    good advice from all three of you.  I will go ahead with this now (after changing my App Store settings).
    Regards, Malcolm
  • Mon, Nov 4 2013 8:45 AM In reply to
    • nhisco
    • Joined on Mon, Nov 4 2013
    • Posts 1
    • Points 15
    Hey guys,
    I was just wondering if anyone can tell me when AVID plans on updating the M-AUDIO Mobile Pre MK II software to make it compatible with Mavericks?
    At the moment I can't use my monitors and unless this problem will be fixed soon it seems I will have to buy a new external soundcard from another supplier.
    Cheers
  • Mon, Nov 4 2013 1:54 PM In reply to
    • Posts 11,268
    • Points 231,960
    hi there.
    no date has been announced on the pro Audio or Pro Video products and there compatibility with Mavericks....
    the following tech note is a good one to subscrib too as - when we do announce - that will be updated.
    http://avid.force.com/pkb/articles/en_US/troubleshooting/Mac-OS-10-9-support-for-Media-Composer-Pro-Tools-Sibelius?
  • Tue, Nov 5 2013 9:44 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,418
    • Points 61,120
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Thanks for the heads up. I haven't yet downloaded "Maverick" but I believe it is a free download at the apple store...
    Mac Pro, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2019.12.1. Pro Tools 11 HD (Mbox... [view my complete system specs]
