Latest post Fri, Jul 1 2016 9:22 AM by Francesco. 2 replies.
  • Sun, Oct 20 2013 6:10 PM
    Background Queue Service is not available at this time
    My background Consolidate/Transcode works flawlesly, but I can't connect to the Background Queue to monitor the progress. When I open this window I get the message:
    Background Queue Service is not available at this time.
    Reason: Connection refused
    In all honesty, I have not reviewed teh documentation to see if any configuration is required. I suspect the architecture of this background processing may require network connection. The computer is connected to a router. Is there a quick fix?
    Igor Ridanovic
    www.HDhead.com
  • Mon, Oct 21 2013 3:28 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    Re: Background Queue Service is not available at this time
    No network connection required Igor but computer performance and computer muscles together with enough Ram seems to be a critical part of it, how about that.
    Tomas
  • Fri, Jul 1 2016 9:22 AM In reply to
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 69
    • Points 680
    Hi
    I experienced the same problem. My configuration is:
    Intel Dual Xeon 2.4GHz
    Windows 10 pro  64 bit with 16G ram
    Avid Media Composer 8.5.3
    When I attempt to display background queue inside MC the result is :
    Background Queue Service is not available at this time. Reason :connection refused
    while if I attempt to display from  AvidBackgroundServicesManager (that is green)
    the result is Internet explorer (11) that displays:
    http://localhost:8185/layout/av-progress-monitor
    This page can’t be displayed
    •Make sure the web address http://localhost:8185 is correct.
    •Look for the page with your search engine.
    •Refresh the page in a few minutes.
    I've disabled firewall and installed java version 8.91 for 64 bit platforms.
    Can you help ?
