Latest post Mon, Aug 13 2018 10:16 AM by luca.mg. 7 replies.
  • Wed, Oct 16 2013 7:34 AM
    • GGEnron
    • Joined on Tue, Oct 23 2012
    • Posts 16
    • Points 210
    Waveforms doesn't show
    Hey
    I have two Avid MC stations at work here where the audio waveforms suddenly stopped showing. I have checked the usual settings people have suggested from similar problems, but this won't help. Yesterday I had waveforms, without changing any settings or doing anything out of the ordinary they stopped showing.
    Here are som print screens:
    1. http://i.imgur.com/LbznOF4.png
    the "Show Marked Waveforms" is unchecked, as suggested in several threads I've read
    2. http://i.imgur.com/PwrgXko.png
    the usual settings I activate/deactive as I like to show the waveforms I want.
    3. http://i.imgur.com/2pUq7mr.png
    proof that the audio I have on the sequence actually has audio.
    This is not a problem for just this specific sequence, other sequences I've worked in earlier that used to have waveforms also stopped showing them, so I have no idea where to go from here.
    Any clever minds out there who could help me with this? Is there some setting or whatever I'm missing or forgetting about?
    Thanks in advance,
    Lasse
  • Wed, Oct 16 2013 1:00 PM In reply to
    • mBlaze
    • Boston
    • Posts 427
    • Points 4,905
    Re: Waveforms doesn't show
    I was running into the same problem.
    I had one timeline setting the was working and another, with similar waveform settings, was not. I tried toggling the settings in the TRACK CONTROL PANEL and the TIMELINE MENU itself - there was no change.
    What ended up working was setting the view to DEFAULT under the TIMELINE MENU and then rebuilding the settings. My settings happen to be settings that were built in an earlier version of the software, I'm wondering if they somehow became corrupt and needed to be rebuilt. Once I rebuilt the setting, I used the OPTION modifier to replace the timeline view I had rebuilt.
    Avid Media Composer 7.0.3 on MacBook Pro 2.5GHz Intel Core i7 [view my complete system specs]
    James Burke
    Video Producer / Editor / Designer
    blog.DVfanatics.com
  • Wed, Oct 16 2013 2:24 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 153
    • Points 1,875
    http://community.avid.com/forums/t/120198.aspx
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Thu, Oct 17 2013 6:24 AM In reply to
    • GGEnron
    • Posts 16
    • Points 210
    So according to that thread Cmd+Opt+L worked on a mac. What would that be similar to on a PC? I tried Ctrl+Alt+L, nothing happened.
  • Thu, Oct 17 2013 6:55 AM In reply to
    • gorky
    • Posts 153
    • Points 1,875
    Have you checked the tracks before that command?
  • Thu, Dec 3 2015 3:39 PM In reply to
    • Kirk Ryad
    • Joined on Fri, May 2 2008
    • Posts 20
    • Points 290
    Wow!! Cmd+Opt+L  worked and solved my problem on Avid 8.4.1
    You wrote this post in the past but solved a problem in the far future!
  • Sun, Aug 12 2018 2:59 PM In reply to
    • spyderrp7
    • Joined on Fri, Oct 28 2011
    • Posts 44
    • Points 610
    I had the exact same problem. Suddenly one day later waveforms stopped showing in all Projects. It drove me mad. Finally found this forum and it worked. On Windows pressing Ctrl+Alt+L brought the waveforms back. Do you know what this command actually does?
  • Mon, Aug 13 2018 10:16 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,712
    • Points 66,980
    spyderrp7:
    CTRL-ALT-k CTRL-ALT-l do shrink/enlarge the waveform.
    Symphony 20.06, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
