Latest post Tue, Sep 24 2013 6:16 PM by luca.mg. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Sep 20 2013 10:19 PM
    • Jay Kadlec
    • Joined on Fri, Apr 20 2012
    • United States
    • Posts 15
    • Points 240
    Won't import + other question
    My Avid 7 interplay edition won't import footage (mov files), and yet it will still ama link and transcode them.
    I've tried re-installing and it still won't do import. It freezes on the import video loading bar and crashes- no error or anything. Any ideas why it's doing this? It was working fine before I upgraded to 7...
    This is just a random glitch I've noticed in Avid 7 and wanted to know if anyone else has had this happen too...So I'll be editing along and then all of a sudden my sequence is gone...no accidental hitting of delete sequence...just gone. I have to go into the Avid Attic to recover it.
    Operating System: MS Windows 7 64-bit SP1--- CPU: AMD Phenom II X6 1090T Thuban 45nm Technology--- RAM: 16.0 GB Dual-Channel DDR3 @ 799MHz (9-11-11-28... [view my complete system specs]
    Jay Kadlec jaykadlec productions | coastline studios
    Filed under: , , , , ,
  • Sun, Sep 22 2013 11:22 AM In reply to
    Re: Won't import + other question
    What kindof QT is it exactly?
    Some QT files, Avid can bypass the QT engine allowing a more efficient conversion (faster and unlikley gamma or color issue). Traditional import strictly depends on QT engine.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Mon, Sep 23 2013 11:37 AM In reply to
    • Jay Kadlec
    • United States
    • Posts 15
    • Points 240
    By what kind of QT do you mean what codec?
    I believe it's an h264 codec (shot on a canon t2i but also does the same thing for Nikon D800 footage, I believe both are h264 codec however).
  • Mon, Sep 23 2013 1:31 PM In reply to
    Have you tried AMA link then transcode?
  • Mon, Sep 23 2013 3:50 PM In reply to
    • Jay Kadlec
    • United States
    • Posts 15
    • Points 240
    "My Avid 7 interplay edition won't import footage (mov files), and yet it will still ama link and transcode them."
    Yes that works fine...and I realize it's basically the same thing...It's just bugging me that the import won't work.
  • Tue, Sep 24 2013 12:39 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    Jay Kadlec:
    No it's not the same thing: it's faster!
    Symphony 20.06, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Tue, Sep 24 2013 12:42 PM In reply to
    luca.mg:
    Jay Kadlec:
    And it's a different process. Legacy import forces you at conform to re-import the whole clip. AMA and you can re-link and Transcode just what you need.
    Import and AMA link - Transcode couldn't be more different.
    But Import should still work....
  • Tue, Sep 24 2013 2:07 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    Pat Horridge:
    To be more precise: back at the time when AMA was first introduced AMA link and consolidate/transcode was faster than straight import, I didn't compare what the speed is like on the latest releases, so things may have changed, my apologies for any inconvenience my statement may have caused.
    peace luca
  • Tue, Sep 24 2013 2:20 PM In reply to
    • Jay Kadlec
    • United States
    • Posts 15
    • Points 240
    When I said basically the same thing I meant that they both get footage into the project.
    I had heard that ama-transcode is a faster process. Question from that fact- then what's the merit of importing?
  • Tue, Sep 24 2013 2:35 PM In reply to
    Jay Kadlec:
    I only import contetn where I know I need all of it and it's a fast import and I want to edit with it in that codec.
    Other than that import is for things I can't AMA
    It's also needed to do conforms for clients that imported their media for offline (rather than AMA and Transcode) and I then get the oppertunity to charge them more for the additional import time and space used.
    An AMA conform can be 5 or 6 times quicker than a batch import conform and that can save hundreds of pounds.
    If you do an import and then an AMA Transcode you'll notice few cores used during the import but most or all during the Transcode.
    That's why I term the import as a legacy process.
  • Tue, Sep 24 2013 6:16 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    Pat Horridge:
    ...and so do I! But as for the QT gamma shift is to be seen what is the best workflow...
    peace luca
