Latest post Thu, Aug 22 2013 3:22 PM by Pat Horridge. 2 replies.
  • Thu, Aug 22 2013 2:35 PM
    • Ian Nicholson
    • Joined on Mon, Aug 9 2010
    • Sydney, Australia
    • Posts 65
    • Points 965
    How do I transcode AMA clips already on my timeline?
    I think a lot of the problems I am having with my current project in MC7 are because I am using AMA when I should have transcoded.
    My project is finished. I just want to Export it, but I keep getting errors which prevent me from exporting. Worse something REALLY bad happens causing all the AMAed sequences in my bin to display as WRONG FORMAT.
    I have a sequence. How can I transcode the clips in the sequence without having to recut the whole video?
    If I try transcoding the original files in the bin, it just creates new files.
    If I try transcoding the sequence, again it just creates new files.
    Any help MUCH appreciated!
    MC 8.5.0 on Intel i7 3770K 3.8GHz, Gigabyte GA-Z77X-D3H, nVidia GTX670 2GB, 16GB RAM, 2 x 128GB SSD, 13TB disk, 2 x HP 2711x 27" LED monitors, Windows... [view my complete system specs]
    Filed under: , , ,
  • Thu, Aug 22 2013 3:18 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    Re: How do I transcode AMA clips already on my timeline?
    Ian Nicholson:
    If you're transcoding a sequence (in a bin), it's going to create new files at the resolution you select, since that is what transcoding does.  You'll have a choice to create a new sequence (or not) and if you choose this option, the new sequence will be linked to the newly created, transcoded files.  Otherwise the original sequence will be linked to the newly created files.  You'll also have the option to include handles, in case you're not completely done trimming.
    If i want to transcode a sequence, I will often duplicate it and put it in a bin of its own, so as to segregate the newly transcoded master clips from AMA clips, etc.
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Thu, Aug 22 2013 3:22 PM In reply to
    Or do a video & audio mixdown of the AMA sequence and have one flat sequence to export same as source.
