Latest post Wed, Aug 14 2013 3:50 AM by Isaac T.. 3 replies.
  • Fri, Aug 9 2013 1:39 PM
    MC7 & OSX 10.8.4 - Can't consolidate footage from CF card
    Our typical workflow (using Avid 6.5.2):
    Start new project in MC.  Create 'Footage' bin.
    Insert CF card into card reader.  CF card will automatically open a new bin in project.
    Drag files from CF bin to Footage bin.  Right click on files in Footage bin and select Consolidate.  Files go to big RAID in Server Room.
    This works.  But now we have upgraded to MC 7 and OSX 10.8.4.   I'm pretty sure I successfully consolidated footage with my system when it was still MC 6.5.2 and OSX 10.8.4.   Anyway now it won't work, here is the error:
    (see attached screenshot)
    "Assertion failed: audioDesc && (0 < audioDesc->GetNumChannels0)
    File:
    /Volumes/Data/Snapshots/relengsnow3_1372098296/coresw/ame/Projects/Mac/_/_/src/msm/MultipleDescriptor.c, Line 462"
    I tried on two indentical systems.  Didn't work.  I have other system still on MC 6.5.2 and OSX 10.7.   It worked.
    So I can keep that system around and do all my consolidating with it, but hopefully soon they will fix this?  Anyone have similar experience or can shed some light?    Also,  when is the horizontal timeline scrolling coming back....
    Thanks!
    Matt
    Avid Symphony 6.0.3 Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon 32 GB 1066 MHz DDR3 Mac OS 10.7.4 [view my complete system specs]
  • Fri, Aug 9 2013 2:15 PM In reply to
    • Edit225
    • Posts 52
    • Points 650
    Re: MC7 & OSX 10.8.4 - Can't consolidate footage from CF card
    Hi Matt,
    Yes, I was having the same problem consolidating clips from an F3.  It seems like only spanned clips are the problem as I was able to consolidate non-spanned clips.  I made the decision to go back to 6.5.3 until some of these bugs are worked out.  Good luck.
    27-inch, Late 2013 iMac, 3.5 GHz Intel Core i7, OS X 10.11.3, 32GB Media Composer 8.5.0 w/Symphony [view my complete system specs]
  • Mon, Aug 12 2013 6:02 PM In reply to
    Ok, guess it helps knowing I'm not the only one, I'll use my old system as a workaround for now.
    thanks for the reply Edit225,
    cheers,
    Matt
  • Wed, Aug 14 2013 3:50 AM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,960
    Or, try this:
    http://community.avid.com/forums/t/121695.aspx
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
