Latest post Tue, Aug 6 2013 1:24 PM by Martin in Chicago. 4 replies.
  • Mon, Aug 5 2013 8:24 PM
    Adjust Levels on All Selected Tracks
    I don't know if this changed w/ MC 6 or 6.5 (I jumped from 5.5 to 6.5), but I can no longer —in the default setup— select, for example, A1 and A2, put a couple of keyframes in each and then adjust the level in one of the keyframes in A1 and have A2 adjust with it. I'm sure this has become a setting now (and I can kind of see the utility of being able to switch back and forth), but I can't find where to set it.
    Maybe I phrased that badly. Let me try again:
    If I select a couple of audio channels in the timeline and hit the keyframe button, I get keyframes on both tracks (provided they have media in them where the position bar is sitting). If I then drag down on one of these keyframes, I bring the level down on that track and that track only. How do I get both tracks to lower simutaneously?
    Hope that was better,
    MC 2018.11.0, OS 10.13.6, Early 2009 Nehalem MacPro4,1, 2 X 2.6 GHz Quad-Core updated with Samsung 850 EVO 1 TB system drive, 32 GB RAM and ATI Radeon... [view my complete system specs]
  • Mon, Aug 5 2013 9:11 PM In reply to
    • mBlaze
    • Boston
    • Posts 427
    • Points 4,905
    Re: Adjust Levels on All Selected Tracks
    If you SHIFT-SELECT the audio keyframes, you can adjust the multiple tracks simultaneously. I know what you mean, it used to gang the keyframes at the same point in the timeline, just by having the appropriate tracks selected.
    Avid Media Composer 7.0.3 on MacBook Pro 2.5GHz Intel Core i7 [view my complete system specs]
    James Burke
    Video Producer / Editor / Designer
    blog.DVfanatics.com
    Filed under: , ,
  • Mon, Aug 5 2013 9:33 PM In reply to
    Thanks James, that was it. Man, I don't really think that's any sort of improvement.
  • Tue, Aug 6 2013 12:12 PM In reply to
    • mBlaze
    • Boston
    • Posts 427
    • Points 4,905
    In doing the audio keyframes that way, you can now move sections up and down (and left and right) without having to mark an IN and an OUT. I think being able to move sections left and right in the timeline is new - I don't remember being able to do that in versions where an IN and OUT point was necessary.
    James Burke
    blog.DVfanatics.com
  • Tue, Aug 6 2013 1:24 PM In reply to
    Previously, holding the OPT key would allow you to move key frames left and right, but, you're correct, you couldn't move more than one per track at a time. Now, if I have a pair of music tracks and a pair of ambience tracks I need to dip for the expanse of a bite of narration, I have to click on eight seperate keyframes to adjust tracks.
    Still, this approach does have advantages as well.
