Latest post Wed, Jul 17 2013 5:33 PM by mjolnarn. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jul 12 2013 7:29 PM
    • Mike
    • Joined on Wed, Jun 29 2011
    • PA
    • Posts 124
    • Points 1,365
    error message when trying to bkgrd trcode ama
    Hello,
    I'm receiving this error when right clicking on an ama linked clip in a bin-selecting transcode, checking run in bkgrd. Yes my bkgrd services are running, anyone else see this or have a workaround? it's gopro footage, trying to tcode to dnx145
    Thanks!
    10.8.4osx, amc v7.0
    macpro mid2010
    *0SX 10.14.3 *MC Ultimate 2018.12.3 *iMacPro (2017) 2.3 GHz Intel Xeon W-18cor*128 GB 2666 MHz DDR4*Radeon Pro Vega 64X 16 GB *AJA IO4KPlus *AVID ISIS... [view my complete system specs]
  • Fri, Jul 12 2013 7:34 PM In reply to
    • Mike
    • PA
    • Posts 124
    • Points 1,365
    Re: error message when trying to bkgrd trcode ama
    message says " The Media Services Engine was unable to make a connection."
  • Wed, Jul 17 2013 4:19 PM In reply to
    • Mike
    • PA
    • Posts 124
    • Points 1,365
    bump
  • Wed, Jul 17 2013 4:21 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Does the same clips transcode well in the foreground
    Tomas
  • Wed, Jul 17 2013 5:03 PM In reply to
    • Mike
    • PA
    • Posts 124
    • Points 1,365
    yes, that isn't an issue
  • Wed, Jul 17 2013 5:33 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Have you seen this document, it´s been updated not long ago, page 13 shows the behaviour of the different icons regarding the bg process, could you check that to see if that behaviour is as it should be
    http://resources.avid.com/SupportFiles/attach/WhatsNew_Editor_v7.0_v11.0.pdf
    Tomas
