Latest post Thu, Jul 11 2013 9:49 PM by Don Carignan. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jul 11 2013 2:40 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 69
    • Points 680
    SampleMapping::SetWorkingImageQuality
    Hi to all
    according to docs, this routine is called by MC in order to set the image quality. It seems that it isn't called depending on video quality menu setting ( in the timeline bottom side window).  That is if I change from Best performance (yellow / yellow) to draft quality (yellow/green) to full quality (green/ green) I didn't see any call at the routine.  Here is the code:
      ACFRESULT ACFMETHODCALLTYPE BLTAPluginSampleMapping::SetWorkingImageQuality (const acfUInt32 track, const acfUInt32 quality)
                 BEGIN_ACF_METHOD
                  if(track>1)
                    throw ACFRESULT(ACF_E_OUT_OF_RANGE);
                  if(quality>100)
                  char db[128];
                  sprintf_s(db,128,"Working image quality %ld",quality);
                  OutputDebugStringA(db);
                   _imgQlty = quality;
                 END_ACF_METHOD
    In my case the only call I see is to SetWorkingImageScale each time I change the quality in the quality menu.
    This happens both in MC5.5 and in MC6.5.
    Moreover : If we have for quality a value between 0 and 100, why in the quality menu we have only three values ?  Is foreseen that in future version of MC we will have a trackbar for quality ?
    Best regards
  • Thu, Jul 11 2013 9:49 PM In reply to
    Re: SampleMapping::SetWorkingImageQuality
    Hi Francesco,
    You should be seeing the call to SetWorkingImageScale() whenever the clip is loaded, when you change the quality in the quality menu, and when doing a render/transcode/AMA-export.
    We don't currently have plans to provide a sliding scale in MC's UI, but we will reevaluate if the need arises.
    Note that the Media Creation Settings...Mixdown&Transcode...Source Quality (Debayer) setting provides finer control:
        kDebayerFull:
            scale = 1.0
            quality = 100
        kDebayerHalfBest:
            scale = 0.5
            quality = 100
        kDebayerHalfGood:
            scale = 0.5
            quality = 50
       kDebayerQuarter:
            scale = 0.25
            quality = 100
        kDebayerEighth:
            scale = 0.125
            quality = 100
        kDebayerSixteenth:
            scale = 0.0625
            quality = 100
    - Don
