Latest post Sat, Jul 6 2013 7:46 AM by camoscato. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Jul 5 2013 11:23 PM
    • chapul
    • Joined on Mon, Jul 1 2013
    • Posts 8
    • Points 120
    No audio on MC 6.5 & 7 export
    Can't seem to export my sequences with audio.
    Have tried it from sequences with var. kinds of media, with different audio track configurations.  Have tried playing the exported QT on var computers, and still no audio.  Export specs are basically for 640 x 360 h264 QT; audio is MPEG4 ACC Enhanced Low Delay encoder, 44 kHZ, normal quality render, 96 kbps target bit rate.
    Have all tracks enabled, and video & audio checked in initial window.
    Have audio box checked in format options window.
    Filed under: , , ,
  • Sat, Jul 6 2013 7:46 AM In reply to
    Re: No audio on MC 6.5 & 7 export
    Someone else posted almost exactly the same question about 2 hours before you did:
    http://community.avid.com/forums/t/120594.aspx
    My answer to him is the same as it is to you:
    camoscato:
    Just for grins, what happens if you set the audio compression to "none" the sample rate to 48, and the bit rate to 16?  Maybe try it on a short test sequence so you don't waste a ton of time testing.
