Latest post Fri, Jul 5 2013 9:54 PM by camoscato. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Jul 5 2013 9:45 PM
    Can't export audio in MC 6.5/7
    Running MC 6.5, and now 7 on older dual quad core Mac pros, OS 10.8
    Can't seem to export my sequences with audio.  Really a mystery.  Have tried it from sequences with var. kinds of media (consolidated Canon XF; 5D markiii transcoded into DNxHD 145), with different audio track configurations.  Have tried playing the exported QT on var computers, and still no audio.  Export specs are for 640 x 360 h264 QT; audio is MPEG4 ACC Enhanced Low Delay encoder, 44 kHZ, normal quality render, 96 kbps target bit rate.  Have all tracks enabled, and video & audio checked in initial window.  Have audio box checked in format options window.  Is it the audio compression type I'm using or one of the var other audio specs I'm using causing this (sequences are proly all 48 kHz audio)?  Something buried in settings elsewhere?  Something in the original sequence?
    Nick.
  • Fri, Jul 5 2013 9:54 PM In reply to
    Re: Can't export audio in MC 6.5/7
    Hi Nick,
    Just for grins, what happens if you set the audio compression to "none" the sample rate to 48, and the bit rate to 16?  Maybe try it on a short test sequence so you don't waste a ton of time testing.
    ciao,
    Carl
