Latest post Mon, May 27 2013 1:45 PM by Bob Jones. 10 replies.
Page 1 of 1 (11 items)
  • Mon, May 27 2013 8:23 AM
    • Bob Jones
    • London UK
    • Posts 38
    • Points 570
    changing avid presets on effects...
    9 times out of 10 i want a white flash.. not a black flash... is there a way of changing the dip to colour, fade to and fade from to e default white not black?
    is it posisble to change preset parameters of effects.?
    thanks
    Bob
    Bob Jones
    edi
    tor
    edit-this.co.uk
    info@edit-this.co.uk
  • Mon, May 27 2013 8:43 AM In reply to
    Re: changing avid presets on effects...
    You can't change the presets, but you can save an effect once you've got it set up the way you like it by dragging the effect icon (pink rectangle) from the top corner of the effect editor window to a bin.  Then when you want to apply the effect to a transition or clip, drag it from the bin to the transition or clip.
    So to use dip to color as an example:
    1. Add dip to color to a transition.
    2. In effects mode, change the color from black to white.
    3. Drag the effect icon from the effect editor to a bin.
    Now you've saved the dip to color with a white transition instead of black, and can apply it from the bin to other transitions.
    Hope that helps.
  • Mon, May 27 2013 9:08 AM In reply to
    • Bob Jones
    • London UK
    • Posts 38
    • Points 570
    thanks.. that i know.. I was just looking for the even easier option of not even having to do that.. ! (lets say it's a slow day at work.. and this is what i seem to spend my time thinking about )
    appreciate the response..
    Bob Jones
    edi
    tor
    edit-this.co.uk
  • Mon, May 27 2013 9:46 AM In reply to
    Bob Jones:
    I don't think there is.
    Bob Jones:
    Great discoveries are often made that way.  :)
  • Mon, May 27 2013 10:36 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    I supose you can export/import effects, creating a VFX libary
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Mon, May 27 2013 11:12 AM In reply to
    Allan:
    You don't even need to do that.  What many people do is create a permanent project, and keep all their leaders, countdowns, slates, etc in that project.  You could also keep a bin full of effects in it, and just open it from whatever project you happen to be in without worrying about accidentally deleting it when you clear the project out at the end.
  • Mon, May 27 2013 12:34 PM In reply to
    • daapap
    • Germany
    • Posts 524
    • Points 6,910
    if you save the effects you want to use time and again to a bin called "Quick Transitions" and open that bin in your project you will have the effects with the individual settings and names you give them in the drop down menu of the quick transition dialogue with the "apply to all"-options included.
    in mc6 you might want to save a bin layout containing this bin and drag this setting into the site settings. so it will open up with every project.
  • Mon, May 27 2013 12:52 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    daapap:
    if you save the effects you want to use time and again to a bin called "Quick Transitions" and open that bin in your project ]
    As it says, that´s for transitions, for effects the bin should be named just FX
    Tomas
  • Mon, May 27 2013 12:55 PM In reply to
    • daapap
    • Germany
    • Posts 524
    • Points 6,910
    he is looking for a way to set a default "dip to white". since this is a transition "Quick Transitions" is the way to go.
  • Mon, May 27 2013 12:58 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    daapap:
    for transitions thats the way to go, just wanted to clarify the differences as effects was mentioned
    Tomas
  • Mon, May 27 2013 1:45 PM In reply to
    • Bob Jones
    • London UK
    • Posts 38
    • Points 570
    Daapap...
    Thanks for that.. i like the quick transitions link into the menu.. thats handy.. appreciate it !
    Bob Jones
    edi
    tor
    edit-this.co.uk
