Latest post Thu, May 16 2013 7:45 AM by Allan. 2 replies.
  • Wed, May 15 2013 11:56 PM
    • adaniel
    • Joined on Mon, Apr 11 2011
    • Posts 7
    • Points 85
    AUDIOEXPORT_INSUFF_DISK, needed on ALL audio clips
    Hey there,
    I'm receiving an error which is AUDIOEXPORT_INSUFF_DISK, needed_in_kb:4301 whenever I am trying to export a video with an audio file in it. It does not matter what audio file it is, in fact, I've exported these audio clips before. I can export video tracks only. I am running off of a RAID and have had no issues with it. I've restarted, restarted the RAID, there is plenty of space, as well as deleted the database files. These aren't large files either. I've also noticed that when exporting that I can now only export audio files to the C:\ drive and not the RAID drive! I'm at my wits end as to what is causing the problem. Any help would be appreciated.
  • Thu, May 16 2013 6:33 AM In reply to
    Re: AUDIOEXPORT_INSUFF_DISK, needed on ALL audio clips
    what are your system specs (detailed!), and did you check your export settings? And what are those export settings?
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Thu, May 16 2013 7:45 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    In Media Creation check that: Import, Mixdown & transcode are pointing at a valid drive
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
