Latest post Wed, May 15 2013 9:49 PM by Randall L. Rike. 1 replies.
Page 1 of 1 (2 items)
  • Wed, May 15 2013 9:18 PM
    • Red Ochre
    • Joined on Fri, Jan 27 2006
    • San Francisco
    • Posts 335
    • Points 4,230
    adding clients to a fiber switch
    definitely not Avid related but I figure that someone here will be able to help with this.
    I'm connecting two new clients to an existing SAN through a fiber switch but I really don't know how to get the switch to see the clients. Is it normally a plug and play scenario or does a fiber switch require a more involved setup? I realize that different switches will be somewhat different but any general guidlines would help.
    Thanks.
  • Wed, May 15 2013 9:49 PM In reply to
    Re: adding clients to a fiber switch
    Once the switch is configured properly, then yes, it IS plug 'n' play.  The ports can be programmed as either clients, drive arrays, etc.
    With Avid compliant switches, Avid provides the correct firmware and confurgation files.
    (wwld)
