Latest post Wed, May 15 2013 6:43 PM by Larry Rubin. 3 replies.
  • Mon, May 13 2013 7:57 PM
    • SunStorm
    • Joined on Mon, May 13 2013
    • Posts 2
    • Points 30
    Media Offline, with a twist
    Or maybe not. I had a "shared" project set up for a filmmaking class at school, all of the media and projects were on a mac. I want to bring them home to continue editing on my laptop mac (and eventually delete the files on the school computer).  Since this was not set up as an "external" we just moved the files over to my external hard drive and tried booting it up at home.  It appears to have worked, BUT I get media offline notices and cant seem to get avid to relink to the files on the external drive.  Any thoughts?
  • Mon, May 13 2013 8:58 PM In reply to
    Re: Media Offline, with a twist
    If you're sure you have all the related MXF media files on the external drive, AND that you have copied your Specific Project folder from the external drive into the master "Avid Projects" folder on your laptop's system drive, AND you are launching the project in the select project window from the copied folder on your laptop, NOT launching it from the project folder on the external drive, then if you are having media offline issues, rebuild the media database. But first, make sure you are following the Avid Media Folder Management Ground Rules:
    1) The "Avid MediaFiles" folder (for MXF media) and the "OMFI MediaFiles" folder (for OMF media if you have any) MUST reside at the root level of the media drive, never inside any other folders or the system will not find the media. The directory should be X:\Avid MediaFiles\MXF\1* where X is the specific media drive.
    2) The folder names must always be the exact factory default names listed above (minus the quotes) or the system will not find the media.
    3) There can be only one of each folder type on any given media drive.
    *There is a 5,000 file limit on numerical folders. When 5,000 is reached, the system will create a "2" folder, move all the contents from "1" into it, and then repopulate "1" with new files. And so on.
    To rebuild the media database, quit the application. Then, from each numerical folder inside the MXF folder inside the Avid MediaFiles folder, delete the two files that identify by type as "MSM Media Database" also identified as "msmFMID.pmr" and "msmMMOB.mdb" . If you have an OMFI MediaFiles folder, delete the same two files. On re-launch, the system will detect the missing files and build new ones at the "Initializing Media Streams Manager" stage. You will see the system go into a scanning and indexing mode at this point. Depending on the number of media drives and total amount of media on your system this could take a while, so good time for a meal break.
  • Wed, May 15 2013 6:29 PM In reply to
    • SunStorm
    • Posts 2
    • Points 30
    Yep, that did it!  Thanks for helping the NOOB.
  • Wed, May 15 2013 6:43 PM In reply to
    You're quite welcome. Happy editing!Yes
